26's & balljoints....
syndicatesteve
Syndicate Steve
Southern California
when running 26's you will run through ball joints. I am currently replacing my ball joints at Network alignment, but I definitly think its worth the cost.
Modded
That Guy
I doubt its the 6s, can almost guarantee its the McGaughys kit causing it. Very commom issue with that kit over at GM FFull Size.
---------- Post added at 03:15 PM ---------- Previous post was at 02:55 PM ----------
BTW what has happende most likely is the McG coils sagged out below the 2" they are suppose to be like they normally do causing exxcessive wear on the BJ. Also one of the front BJs can't be pressed out, meaning you need a whole new UCA, think its the drivers side that has that issue.
NORCAL SS
SUV SUSPENSION GURU
bad balljoint angles thats whats killing it. Ive been seeing this with drop springs. one reason i like the djm arms also just dont need to deal with it on the 07 up trucks.
how many miles on it anyway??
kickitandholdit
GA
it wont be as bad if you grese your ball joints regularly with a grese gun
Modded
That Guy
Well I think its mainly the springs sagging causing bad angles. Most drop springs shold not cause that.
Also kickandholdit the BJ aren't even greasable with a grease gun IIRC.
syndicatesteve
syndicatesteve
Syndicate Steve
Southern California
The Ball Joints dont have Grease Fittings. I chose the McGaughy's Lowering componants because they are the only lowering componants that GM will allow without voiding warranty. I checked this with my local GM dealer as well as their Regional Rep. My Yukon has 40k miles, so I am not too upset about replacing the BJ's.
---------- Post added at 01:05 AM ---------- Previous post was at 01:00 AM ----------
Does DJM Make a kit for the 2007-2010 Yukon?
Modded
That Guy
Yes they do have a DJM kit Syndicate, I have there rear 4" kit and its lower than the 5" kit on from the McG :confused:
BTW the only thing spindles can void in a suspension are the ball joints, UCA, LCA, strut and tie end rod.
The Belltech kit does not void these either, my bro had it on his Esky with 0 problems.
BTW did you have to get a new Upper control arm?
BOSS
The People's A D M I N
Dallas
Balljoints wear out on even late model daily driver vehicles, most just don't know it because they don't take the knuckle off and check.
B
syndicatesteve
syndicatesteve
Syndicate Steve
Southern California
well with my McGaughy's kit, I am sitting 3/4 " off my bumpstops in the rear. I want to change my upper and lower control arms, but I think if I am going to go to that expense, I am just going to bag the whole truck. All I am waiting for now is the new daily driver so I can park the Yukon. The only way I noticed I needed new ball joints was because i had the front end apart cleaning for a show. Really they were just sloppy, I could have let it go a little longer, but I don't want to risk damaging the truck.
NASTY GM
Nor Cal
I have 47k on my 07 with no problems, with 15k of those beoing on my 26's. I'm lowered more than 3" in the front :think:
Mlstammerjr
