Truck info
ybnorml67
Hey guys. New here. I just bought a 2009 2wd Tahoe. It was purchased at an auction back in 2015 by its first civilian owner.
I'm not new to Chevy trucks or customizing them, just this generation.
I have a few questions :
How do I know if it's a SSV or a PPV? And what is the difference between the two.
Is there anything I should know about the suspension before lowering it? IE, is it different from a regular 4x2 truck?
I plan on lowering it and throwing on some later model factory 22's.
Adding a trailer hitch? Mine just has a square tubing where the hitch would be, do I just swap the bar out with one from a stock truck?
Y
ybnorml67
0k, so its a PPV. Thanks
Is there anything special about the suspension that I should know before ordering my lowering components? I haven't seen any info anywhere else but i'd hate to order parts and find out they're redundant.
kbuskill
NE. FL.
There is alot of info on this site... the spring rates are different I believe and the lower control arms are cast aluminum like the 4x4 models instead of steel like most of the 2wd models.
Y
ybnorml67
Thanks, I have searched this forum as well as another forum that I belong to.
Some guys state that these are lower than a regular 2wd Tahoe, others say its just the tires.
kbuskill
NE. FL.
Forgot to mention... I believe the PPV runs the bigger sway bars from the 4x4's as well.
Kwilson1671
Look at the speedo, PPV goes to 140, ssv goes to 120. PPV is lowered by 3 to 4 inches and is wider for cornering, hence the pursuit vehicle in the name. Wiring is the same plus has extra added under the center dash, behind the glove box and drivers side back. You can look up the manual that comes with them on the web. They have a lot of equipment deleted but can be added. I added the DIC switch, and rear door locking rods so everything is basically normal.
RichardCranium
Mebane, North Carolina
Looks much better with the black wheels IMO, at least until you get it set up the way you want. And that hugger C10 with the big steelies looks damn good!
992dr
Eastern N.C.
Welcome aboard :)
Lookin good man and I have to agree with RC, the C10 is pretty bad ass.
PPVs suspension is lowered 2" all around.
Y
ybnorml67
I checked the speedo, 120mph. Probably explains why the truck is in such good shape.
Thanks, I like the Black wheels as well. I plan on keeping them for winter rims.
Welcome aboard :)
Thanks, after some quick measuring against my buddies 2011 Denali. I can confirm that my truck is the same height. I measured from bottom of fender lip to center of hub and both trucks are within 1/2" of each other.
Another quick question, I haven't noticed many off topic vehicles posted on this site. Is it alright? If so, I could throw up a few pics of the other rides of built on here.
992dr
Eastern N.C.
From the sound of it, sounds like you have yourself an SSV.
Of course you can post about other vehicles. If you scroll down on the main page you will see "General Info". In that section is listed as "garage". Post away my friend :)
Y
ybnorml67
Thats the conclusion that I have come to as well. SSV it is.
I just thought I would ask about the off topic vehicles. I used to belong to another forum where the mere mention of an off topic vehicle would cause massive outrage
992dr
Eastern N.C.
Congrats on the new to you SSV, haha
I hear yah, some forums are kinda finicky. This one though, not much at all.
I'll be keeping my eye out for your thread ;)
Y
ybnorml67
I haven't posted in awhile
But I've been busy.
I threw in a bell tech drop kit. 4/4.
It's too much in the front, which is no big deal as I can add the supplied spacers and lift the front up 1"
The rear unfortunately only dropped 2". But I'll live with it.
I also scored a set of GM Elevation 20" wheels.
Y
ybnorml67
I've never been a fan of black wheels but I think they look pretty good with the white.
jz57
Look at PRO code in glove box:
PPV = Z56
SSV= 5W4
992dr
Eastern N.C.
But I've been busy.
View attachment 184437 View attachment 184438
Man, that looks great.
Did the rear ever settle down? I'm curious why it only lowered it 2" instead of 4".
briannorris
