Regency
Put smokey on the rear window and did an oil change.
M3kanic
How many miles do you use amsoil for?
M3kanic
Ok. I know some honda guys are religious about having their oil tested and they can get up to 15k out of Amsoil. I didn't know if you went off of your dic or not. I normally get about that out of mine as well.
Regency
Yeah. 8k is about as much as I've let it go.
chilleblanco36
About to change the oil with some Mobil 1 Synthetic and an A.C. Delco filter
Held 6 qts exactly
Sent from my SAMSUNG-SM-G935A using Tapatalk
PG01
Up here to the right
Minty......hahahlolol.....
its CHRISPY.... like when you open something new and its all nice new and chrispy....
PG01
Held 6 qts exactly
Exactly?
I cleaned my engine...finally
Dont tell them what you used.... let 'em guess...
chilleblanco36
Just curious as I need to clean mine.
Ciro
Looks great, care to elaborate? Did you use a hose or pressure washer? Did you cover electronics, ETC?
I just covered the alternator and battery, You're not really going to hurt much of the electrical components with clean water, all the connectors have seals that keeps moisture out. Never use a pressure washer to clean the engine.
Ciro
This is a guide I found online and it is exactly what I did:
  1. Make sure your engine is warm. Not hot. Just let it run for a few minutes. This will help loosen the dirt.
  2. Cover the alternator, battery, and any wires/plugs/important parts if you have concerns.
  3. LIGHTLY spray down the engine bay. You don't want a strong jet of water here.
  4. Spray on your degreaser.
  5. Agitate with brushes/microfibers.
  6. Spray water again to remove the dirt.
  7. Repeat/spot clean as necessary.
  8. Carefully remove covers on the electrical parts.
  9. Wipe down.
  10. Turn the car on and let it run for a few minutes and check for warning lights.
  11. Dress if desired
  12. Take pictures and post them in the forum :)
Hodmjstone
