juan84
2014 Yukon Denali XL ... Here's what's happening every thing is fine till I close the door tia
That's where I tapped the lc2i into .where did u tap for feed
sent from galaxy s6
I'll try that thanksIt's the noise cancellation system. It's activated when the doors are closed. Took me months to figure out. There are 2 round vent looking pieces slightly larger than a quarter on the drivers side. The noise cancellation one is the back one I believe. Open drivers door and remove the rubber around the door frame so you can slide your hand between the roof and the headliner.there should be some wire under some foam block. It is kinda hard to pull loose. There will be a green plug on the wire. Unplug the green plug and it should fix the problem. Do not try to pop the covers off from underneath. I did and one broke. Lesson learned. Hope this fixes your issue.
