2015 Yukon Style Tail lights
Graystone_OG
NYC
Anyone have these yet? They look pretty good. Just don't like that smooth outer surface. Make's the back look too round. Link
Graystone_OG
Graystone_OG
NYC
These would complement the Optic tube headlights nicely.
morriskb
Missouri
I just posted this on a different thread. These went on relatively easy and look fantastic. The only issue I had was disconnecting the original harness which is located underneath the vehicle. Additionally, you need to provide your own 3157 bulb since the OEM bulb is a different size.
Since they are of the aftermarket variety, I've seen some condensate buildup on occasion, but it dries itself out in the sun. A bead of silicone around the seals will rectify that.
Mike S
Anyone having issues with the 2015 Tail light going out? I have 60k miles and my drivers side keeps going on and off. Failed safety inspection because of it
DenaliEd
MN/IA
I think you're in the wrong post. This was about an aftermarket light for the 2007-2014 trucks that looks like the 2015. You're clearly looking for input on your 2015 model Yukon that has a light issue. I'd say there's a bad connection somewhere, but I don't know whether your truck has LED's that are a sealed unit or incandescent bulbs that might just have loose tabs in a socket. Tail-lamps are generally easy to remove and from there maybe you can assess what's wrong. Hope that helps.
HeavyHoe03
