6" rear drop control arm info
992dr
Eastern N.C.
How much does the 6" drop move the rear out of alignment?
How long is the control arm (from center of eye to center of eye) to center it back in the wheel well?
Thanks
coryd
Southwest FL
Thanks
The 6" drop pulls the rear end forward a good amount, definitely noticeable. I can't speak to exact measurements but I used the Spohn adjustable upper and lowers with my 6" drop and they work perfectly, along with the Spohn adjustable panhard bar.
992dr
992dr
Eastern N.C.
Hey Cory,
Thanks for the info.
I'll have to take some measurements when I'm dropped and go from there.
ddubdb3
hey when you installed the spohn arms did you adjust for diff pinion angle as well or just lengthin all the bars just to center the rear wheel?
coryd
Southwest FL
I had a shop install the kit, pretty sure they just lengthened the bars to center the wheels. I would guess Tony (NorcalSS) would be able to speak to how pinion angle figures in when using these.
Durobans
