I really need to replace my tie rods and pitmen idler arms. but I have spend most of my money until the end of june. I would like to go cheaper. Any thoughts?
What OEM problems? Like what?Ive found that they are over priced compared to AC Delco Pro. Moog does make some problem solver parts to fix a known problem with OEM. If the OEM parts worked fine but are just worn due to high mileage then why not put new ones of the same make back on? I probably will never spend MOOG money on front end parts ever again unless I run into a OEM problem that is well documented that someone like Moog has fixed in their design.
Any parts come to mind?Sometimes OEM parts are of original design and known for premature failure or issues with the performance of the part. Some aftermarket manufacturers engineer improvements over the original design to make the part more robust, ease the installation, or just plain outlast and perform the task better.
This is not an area you want to cheap out on or you'll be doing the same job again in 6 months
I have to ask. Sometimes we just don't have the money to go with the best parts. I just might have to install a piece at a time.
One does come to mind, the ball joints for the 91-99 suburban, OEM does not have a grease fitting while most aftermarket parts do. If I am not mistaken, Moog uses better quality hardened steel on theirs than stock also.Any parts come to mind?
If your doing tie rod ends, pitman arm etc. it's best to do it all at once cause you need to get an alignment for all of that, and plus if you do it piece by piece your alignment might be off and in turn you might damage your new parts if you don't do it all at once
Well if you want to go crazy and do it all, here's what I'd do (and have done)
Pitman arm
Idler arm
Idler Link arm
Inner and outer tie rods (both sides)
Upper and lower ball joints (both sides)
Front shocks
Sway bar end links
