Cold air intake? Yea or nay?
Dr P
Sorry guys I'm not sure how to post on here. But I was wondering if on a 2004 Chevy tahoe do i need to drop the oil pan to remove the oil pump or can I just remove the timing cover??
02_Tahoe
Maryland
Just saying when I click on your link I get no results. Bad link.
Turn off the vigilink thing, that's what's messing it up. On the bottom is says "why am I seeing this" click on that. Then is should say "click here" to disable then you can go right to the page
Shunto
Long I$land NY
Link worked for me.. I've never heard of that brand before.... Ya gets what you pay for .. it's never proven me wrong yet.
Etraeger
Kalifornia
Does it really matter how "cool" it looks if its going to be hidden under your hood anyway? I talked to my mechanic who has dyno'd CAI's and found no HP increase. I didn't ask him about fuel economy. It does increase engine noise he said.
jarydM
Lost in the Woods
Tennessee
BlackBear Tuning did a test. Get an AirAid Jr and call it a day...
this is the answer.
CAIs give you a power "boost" due to colder air, problem with our trucks is that we ALREADY have a CAI in the stock box. You can gain a modest increase with a better tube (less restrictions) and a hi-flow filter. I bought a cheap CAI kit, and connected it to my stock box, because I didn't want to (or have) $150 dollars for an intake tube.
nofaz
Bismarck
Has anyone experimented with a functional cowl induction hood? I'd be real curious to know if there is any measurable power or economy to be gained doing this. Yeah I know they look cool but it would be better if they would actually do some good.
Msalinas408
Has anyone had any experience with aFe Power Cold Air Intakes?
Tacky
Yes, pan has to come off.
They just look good but do nothing as far as performance since our trucks draw cold air from the fender.
nofaz
Bismarck
I know it would take some additional hardware to get it plumbed into the filter box but I'd like to hear from someone who did it. This would allow the engine to draw air from the pressure bubble that forms at the base of the windshield while at highway speeds. Some of the muscle cars of the 60s and 70s had functional cowl induction. NASCAR uses the same theory but taps into the defroster intake just below the windshield. This can cause a bit more noise in the cockpit though.
jarydM
Lost in the Woods
Tennessee
unless you are constantly over 90mph, I can't imagine this being the case. Even the Cowl inductions of the muscle cars of old weren't able to utilize this. Nascar, yes, but we are talking about 120+mph
So you would take it from the cowl to the filter box and then back to the throttle body? Seems like a long trip.
Also the old muscle cars had an air filter sitting on top of a carb which is a better scenario for this than our setup.
nofaz
Bismarck
Theoretically, you could pull the air out at the front of the hood as the entire scoop would be pressurized at speed. This would make the connection to the air box considerably shorter. I was hoping that there was someone here as crazy as I was that knew how to fabricate and had put a cowl induction hood to its proper use! Thanks for the replies.
02_Tahoe
Maryland
What about these things?
jarydM
Lost in the Woods
Tennessee
I looked at them, 2 things.
1) your TB is a 4" hole, so get a 4" pipe.
2) those accordion type pipes still create a lot of turbulence inside, while it might be ok for a short distance, I wouldn't really want one in there, especially when you can do it with one straight pipe.
02_Tahoe
Maryland
2) those accordion type pipes still create a lot of turbulence inside, while it might be ok for a short distance, I wouldn't really want one in there, especially when you can do it with one straight pipe. View attachment 79699
Did you buy a whole intake kit and use just the pipe?
CrackerJack135
