My Maintenance List *issues*
BlizzardX23
Sacramento, California
Feels like my truck is slowin down a bit...not as quick..mainly when its super cold...
I believe one of my 02 sensors have been bad for about 2 1/2 years now...I've known about it for a long time...just never did anything about it...so I'll probably replace my sensors (how many? ...4? and where can you get them for cheap?)...I wanna replace all my plugs and wires as well....fuel filter was done about before I deployed, so it only has about 1 year of drive time since I had it replaced..
main question is about the 02's....Im hoping they arent like $80 a piece or anything
puckhead
CO
Would like to know as well. O2's seem to be a pain on these trucks
Tonygxp
Toms River, N.J.
easy to see if they're switching they're working. have it scanned. you would most likely throw a code if there was a problem IMO
BlizzardX23
BlizzardX23
I've been throwing a code for one of my 02s for a long time...dont remember which one though...I've just never done anything about it because the truck has been running fine and it was never a priority
puckhead
CO
If its the same coed mines been throwing its the P1404 code. Description of: Manufacturer Control, Auxiliary Emission, Controls. Ive always been told its the O2's or EGR
BlizzardX23
BlizzardX23
TIM Z
DMAX Power
Navarre Ohio
How many miles on your engine?
If over 90,000 i'd def change the front two oxygen sensors. rear ones dont really affect engine closed loop operation.
Lazy O2 sensors rob you of performance and usually 1-2 MPG. They are worth replacing even though they are expensive.
Fuel filter is in your tank, dont worry about it.
I'd get only AC delco plugs.
Also run a can or two of berryman chemtool fuel cleaner thru your tank. That stuff is awesome for cleaning the gunk out of injectors.
Thats pretty much all you can do for maintainence with out tuning software.
BlizzardX23
BlizzardX23
The fuel filter has already been replaced..but why stay with ACDelco? I think your right about the MPG =/ I've noticed its gone down about 1mpg in the city
the truck just passed 100k miles last month
which side is bank 1? (with #1 piston?)
TIM Z
DMAX Power
Navarre Ohio
I always run AC delco plugs when tuning up.
They always perform well and last a long time. I dont like the new "fad" plugs.
The delcos are designed to last 100,000 ( platinum) .
But get what you like.:)
Yeah, if you lost MPG i would def. replace your O2 sensors. Cant go wrong.
Shop around, you may be able to save some money on them, they are a little pricey.
I do believe Bank 1 is your drivers side Odd cylinders, but i need to look it up for sure.
BlizzardX23
BlizzardX23
That would make sense because...my issue is bank 2 (from the code)
and the passenger side has destroyed (2) catalytic converters in a 13 month time frame before I switched it to a high flow...
TIM Z
DMAX Power
Navarre Ohio
hmmm, now you got something to do in your spare time!
Maybe santa can bring you some tune up goodies!
Modded
That Guy
WOW Bliz you just really posted in the 07 secction? :slap:
Anybody over 500 post has no excuse for that.
Nickleahy23
Portage/Menomonie, WI
replace the 2 upstream o2 sensors (before the cats) and forget about the other 2...just get your damn BB tune and have him turn the rear ones off...as soon as i get some cash i need to do mine..155k on the stocks i believe haha...i have a rattling in the y pipe that i believe is a broken cat as well..i cant wait to be able to afford some headers
Modded
That Guy
LoL I just had to come and skew the thread a bit!!
I can tell you its not the filter causing your issues, I say sway up the Cats, clean air filter and MAF sensor, run seafoam, maybe do the plugs like you said......
OR WASH YOUR TRUCK :pokeowned:
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
Haha, he cant, Its 90% un painted cause he wont get his fenders painted or finish painting his wheels.
rigo_jones
going against
DENVER mexico
u should find some cheap O2s on ebay but u really dont want cheap.. bosch is best but will cost more. if u r getting a tune just disable the secondary O2s but than u wont pass emissions i think.
CrackerJack135
