Whipple or Maggie?
Young28
The Yukon God
ga
Yeah too much for me. I just ordered some 50 LB Delphi's with adapter harnesses for $150 total. Ordering the Whipple tomorrow. Also ordered knock sensors & harness, valley cover gasket and oil pressure sending unit. I hope this goes well. Brandon @Young28 what are you rolling in now? You parted out the bagged Denali didn't you?
Yea i don't blame you on not spending $500 for injectors after spending all that other money right now. Yea most of the Denali is gone. I kept the motor and stereo stuff and brakes. Everything is in a 05 Silverado now except the stereo. That should happen within the month though. It's taken 30 months to get a tag for my 05. A lot of bull crap happened with different companies getting the run around etc . I found the right guy to help me now. He also live a mile from me so it's perfect. Injectors are now. Then maybe heads but I'm going to see what I think with the new injectors. Hell keeping the truck in a straight line is already a problem lol.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
It's a done deal. Justin @ BlackBear sent an invoice for the blower over and I just paid it so it's official. I also learned my truck has EGR so I ordered an EGR delete set of block off plates.
Gonna have to rename yourself. Super Red Rocket
Looks like it will be a month or so before it ships. According to BBP Whipple has been slammed.
sumo
rhode island
After install, I suggest you get it dynoed and log the runs. Are you getting the tunes from black bear? I dynoed mine and sent him the files. Justin was able to fine tune specific areas of my fuel trims and now I feel confident that my truck is running in top shape
HiHoeSilver
Away!
Chicago
This.
I guess I'll try to find a 4-wheel dyno locally since mine's an AWD.
@sumo did you have to upgrade your fuel pump with a high-flow one? One more thing I've been wondering.
JennaBear
Resident Ninja
San Diego, CA
No real need for a dyno. If you are concerned, you can always buy an AFR sensor to plus into the AutoCal.
sumo
rhode island
Nope stock pump with injectors that came with blower rated for flex fuel. Flex injectors flows more
Than non flex. No problems, knock or ping when using shell only 93 octane. If you have flex, you want be able to run e 85 according to Justin.
I don't have flex fuel, it wasn't an option in '02. I bought some flex injectors out of a '10 rated at 50 lbs/ hr though. Thanks for the info on the pump.
I can get 3 AWD dyno pulls for $100 though and that will let me know what I'm getting to the wheels also. Although an AFR sensor and gauge would be cool although I have no idea how to install one. Would I have to weld a bung in the exhaust? Also, how would I connect it to the Autocal?
bottomline2000
Dallas, TX
I have an AEM wideband gauge to install. Simple pos/negative connection to a switched ignition source. U can data log your fuel trim thru the egr 5v connection to the ecm since u are not using it anymore using the autocal. The gauge comes with a bung u can have welded into the exhaust.
sumo
rhode island
You can have Justin tune out the rear o2 sensors. I uninstalled a oem o2 and plugged the wideband in there
How do I connect it to the ecm and have the Autocal recognize it? I'm lost there.
bottomline2000
Dallas, TX
Justin said and from what I've found online u connect the wideband to pin 55 on the ecm which is for egr voltage. The autocal plugs into the obd2 port like normal and is reading EGR voltage which is actually the wideband's voltage output of a/f ratio. Conversion looks like this..
briannorris
