JT 07LTZ
Are these the 5100s to order for a level kit. Just need to make sure before ordering
Yes, those are the correct 5100's. I used them on mine and they ride great!
I've got the same amount of lift, a 34 may be stuffed in there, as long as you keep the tire on the skinner side possibly a 275/65r20. There was alot of trimming involved to fit a 305/55r20 in there with 3"I'm searching for tires now to go with my lift. I wanted to keep my 20" wheels, but i definitely want to see more sidewall. Will I need Spacers with 34" tires? 33's seem to fit nice with no extra hardware.
That's exactly the tire size i wanted 275-65-20. I don't mind trimming a little bit. I just wanted more side wall on the stock 20's. I've read a lot of great things about falken AT3W's. Hopefully in the next few weeks i'll pick up a set.I've got the same amount of lift, a 34 may be stuffed in there, as long as you keep the tire on the skinner side possibly a 275/65r20. There was alot of trimming involved to fit a 305/55r20 in there with 3"
That's a good point. I never really thought about that. I meant wheel spacers but i didnt like the idea of those. I have a 3/2 lift on it and thought i would gain a lot more space then i actually did.Not sure if you mean suspension spacers or wheel spacers.
I wouldn't do wheel spacers on anything. It will increase the radius of the sweep that your tire takes from lock to lock. Adding spacers will actually DECREASE the clearance.
Suspension spacers are the first step to extra tire clearance for bigger tires. Get a 2"-2.5" depending on your desired tire size.
@01Konvict the Suburban is gone bro. Will update this week.traded in for reasons out of my control
2.25 front and 1.5 rear, kit from 4wheel parts.Nice! How many inches Is your leveling
New Suspension: Pro Comp Pro Runner rear shocks and Front struts.
What
