Let's see some pics of some lifted and leveled
Fg8or
just replaced my rears. Think the originals were a little shot!
JT 07LTZ
Western, NC
Wow yep I'd say those are shot. My Autoride shocks didn't even look that bad but were leaking and the compressor was burnt out.
dvoffroad
Ok, my head is kinda spinning after reading through this whole thread. I have a 08 LT Hoe (non autoride) and I am looking to put some 275/60/20 Duratracs on it. Will I be able to do so with just a 2/1 level or will I also need to add the Bilstein shocks? I plan on leaving on the boards (short wife) and running the stock 20 inch rims (may add spacers).
Thanks!
mdhawk
Reading, PA
I'm searching for tires now to go with my lift. I wanted to keep my 20" wheels, but i definitely want to see more sidewall. Will I need Spacers with 34" tires? 33's seem to fit nice with no extra hardware.
Bigmac18
I've got the same amount of lift, a 34 may be stuffed in there, as long as you keep the tire on the skinner side possibly a 275/65r20. There was alot of trimming involved to fit a 305/55r20 in there with 3"
NGAneer
NWGA
I've got a 2.5" TGC and 305/55 Falkens. A few hammer blows to the rear of the front fender well and some plastic trimming was all it took. I've got >1" of clearance all the way around. Only rubs the sway bar when at full lock.
NGAneer
NWGA
Not sure if you mean suspension spacers or wheel spacers.
I wouldn't do wheel spacers on anything. It will increase the radius of the sweep that your tire takes from lock to lock. Adding spacers will actually DECREASE the clearance.
Suspension spacers are the first step to extra tire clearance for bigger tires. Get a 2"-2.5" depending on your desired tire size.
mdhawk
Reading, PA
That's exactly the tire size i wanted 275-65-20. I don't mind trimming a little bit. I just wanted more side wall on the stock 20's. I've read a lot of great things about falken AT3W's. Hopefully in the next few weeks i'll pick up a set.
mdhawk
Reading, PA
That's a good point. I never really thought about that. I meant wheel spacers but i didnt like the idea of those. I have a 3/2 lift on it and thought i would gain a lot more space then i actually did.
01Konvict
Boats n Hoes
Raleigh/SML
@01Konvict the Suburban is gone bro. Will update this week. :( traded in for reasons out of my control
Damnt dude you got it setup right after those brackets. Now since it's gone you better post all the pics of it! Side note I got my Denali driveshafts made and all good now. No issues or vibrations.
Drewphil
