bottomline2000
Dallas, TX
I thought I saw one on there at one time but maybe I'm wrong. If you're okay with spending optima kind of money, look at north star batteries. The one for our rigs has the highest cca and reserve capacity I've found to date, without shelling out stupid money for a lithium battery of course.
I currently have a diehard platinum agm with 880cca but it's been reading low at the top post with a side post issue reading extremely low. I don't mind spending the money for quality. My truck is currently in the shop so I'll have to wait until it's out to check the connections one last time. I'm done with Optima, been there done that. I'll check out Northstar. I just want something proven.
derek1387
Dropped off my new HD hood to be painted...and installed a remote start!
Rebelmyers
What remote start did you Install been considering doing that myself
Fosscore
Took out the Escalade style gauge cluster and shipped it off to have the VIN, mileage and hours corrected. Also having blue LED's put in.
This will look sweet in blue. Post up who you are using.
TM98
Used the leftover 1/0 gauge I had from my camaros battery relocation to do the big three. Used a stinger fuse box off the battery to be safe and wrapped it all in black nylon techflex because lime greens just too much for the Denali lol
So far haven't noticed too much of a difference, but apparently the people on gmfs have noticed a 1-2 mpg increase so I'll be on the watch for that.
Where did you buy the wire and techflex?
bottomline2000
Dallas, TX
Hate to quote myself but the Northstar battery looks identical to my diehard platinum. It's been a good battery other than one side basically going dead lol. I'm charging it with a DC power engineering 270a alternator yet it still reads low on CCA. Anyone using these or other AGM battery with any luck?
Not sure why the gasket pic showed up...
Sent from my fone
jarydM
Lost in the Woods
Tennessee
Sent from my fone
your phone is reading my mind, about to do those, and the valve cover gaskets.
DDenali
Orangeburg, SC
Sent from my fone
I definitely need to get that do also
1992rs
OR
I get my wire at Knukonceptz and my Techflex at wirecare.com
Sent from my fone
It most likely is. Theres only three or four major battery brands in the US so all name brands and house brands will fall under those 3 or 4 companies. The only difference aside from looks is the grade of lead that is used. From everything I've heard, diehards one of the better brands out there. 880 cca is no slouch lol How old is your DieHard? Also theres always dual batteries if you really need more juice.
Braille makes some really high end (and light weight batteries) but its only a top post, unless you jump to their lithium ion battery and want to dump $2500 on a battery lol
https://www.braillebattery.com/index.php/braille/product_batteries/b6034
I might email them and ask about creating a dual post battery 34/78 battery. All they really need to do is add a side post to the one in the link, I'm sure it cant be that hard and costly lol
bottomline2000
Dallas, TX
I've had the battery about 6-7 years. I don't know when it went back since I've had my big 3 setup the entire time. It still cranks fine as long as the top ground post is connected, but I had it tested and was only showing 660cca. The voltage on the alternator is good and nothing tells me the amperage output is not what it should be. It hits 14.8 at startup and drops to 14.3 hot..it s a stud lol.
I'll look into getting the same one rebranded. It's been good to me and still looks new.
I would only consider the lithium if I were putting them in a boat.. a Lotta coin for a battery.
I'll look into getting the same one rebranded. It's been good to me and still looks new. My alternator and my power grid lol.
Sent from my SAMSUNG-SM-G900A using Tapatalk
1992rs
OR
I'd only buy one for my camaro since Its going towards more of a track car. They have ones that put out just as much or more cranking amps as our batteries at only 9lbs!
wwiizz
