UATahoe
One of those pics is actually of my Z71. LOL. Love those rims. I am actually in the process of doing a ton mods to mine. Was thinking about selling it but i just love this truck. Cant go wrong with tbss wheels.
NGAneer
NWGA
I'm thinking it has something to do with the Intake manifold as I just replaced all the gaskets. I pulled the intake back off and going over everything again as we speak. If that doesn't fix it, I'm going to take it to a buddies Muffler shop and go all out with Headers, Hi-Flow cats all hooked up to my MBRP exhaust :)
Love it. Nothing better than turning a repair into an upgrade. I'm waiting to pop a head gasket to give me an excuse to do a cam swap.
NGAneer
NWGA
Added some 26" replicas on my Escalade..
Sent from my SAMSUNG-SM-G928A using Tapatalk
This looks epic. Definitely a tie for my favorite OEM wheel.
Yeah, justifying it to the wife is easy with a blown head gasket though.
Either one can kill your motor. IMO, the AFM will fail long before a head gasket does. With an AFM failure, you don't really have any warning and it can do a lot of damage to where the engine may need to be rebuilt or replaced. If a head gasket fails, you usually have some sort of indication and can park the truck until it's repaired. So, the AFM needs to be deleted before it fails, the head gasket can stay until it fails. As a bonus, it will get new head gaskets when you delete the AFM/swap the cam, then it'll be good to go for 300,000 miles. Explain all of this to her AFTER you pull rank and order your cam and lifters.;)
DaRosa218
The Dude abides
Modesto, California
Well, seems like my AFM is failing. When de-accelerating I get a rapid drop in oil pressure and the truck goes from V8 to V4 mode and will not let me accelerate for about 5-7 seconds and then jumps back into V8 mode and everything is fine including oil pressure.
Cold my oil pressure is around 75psi and warm my pressure is about 60psi. When the oil pressure dips, it drops to about 30psi, activates V4 mode then climbs back up to 60psi and V8 mode returns. I'm thinking it's a sensor gone bad since I was just in the oil valley not to long ago and everything looked pretty tarnished.
Fosscore
Showed the wife how to unlock her power running boards. Lol..she must have bumped the ASC switch when plugging in the USB cable on the passenger side.
Now she knows. :)
Jonah52
Senor ******
Cleveland
Dropped it off for some much needed love at my buddies shop. The list includes the following:
New Oil pan gasket ($190)
Detail all leaked oil from front diff area
New drain plug with (seal was bad) ($6)
Oil change and filter ($30)
New rear wiper ($6)
Greased slip yoke to eliminate clunk
Going to the dealer next week to get quote on fixing my console lid and driver seat. I was going to go look at a summit white short bus 2010 Denali tomorrow with 80K on it, but when its all said and done I'll have roughly $500 into these small fixes and little quirks, and it will function just as good, for much cheaper!
In addition, the Corsa exhaust fell through, unfortunately, (which allowed me to do all the fixes) which sucks, but isn't such a bad thing in hind sight. I did still get a Superchips Flashpaq and OEM chrome tow hooks, so that should be fun.
After that I will be grabbing a K&N intake from a local forum member, some LED fog bulbs (5000k), and then I have to think of more ideas! hahahaha
AppocAlexx
Darth Appocalexx
Abilene TX
Order some new rubbers Nitto G3s 275 60 20s.
Had a question as well, anyone know if the 16 model tails fit our models? Saw a 16 model driving around kind of liked the tails thought they would look nice on my 07.
Also any good links for replacing seals and bearings on the front diff. Iv got a good little whine up front and I'm thinking that may be the culprit. Thanks.
Jonah52
Senor ******
Cleveland
I'd say 99% they don't fit. Completely different body
blkonblk
NYC
had a few things installed today:
Front/Back OEM shocks
Suspension Compressor OEM
Front/Back, Upper/Lower control arms OEM
Front/Back Hellwig sway bars
Front energy suspension links, kept the djm end links in the back
Front R1 Concept Rotors with some Hawk pads
Headrest Concept 905 BSD/BSS dvd
fun day
08HoeCD
fun day
Cool.
How does she ride/feel now?
Jonah52
Senor ******
Cleveland
How are the sways? Less body roll when taking off and braking?
Did the end links make a difference at all?
fun day
Dank Denali
washed her :). Ill get a pic up eventually but too lazy to upload to some image hosting site at the moment
NGAneer
NWGA
Broke sway bar end links... both of them. Angles from the sway bar to control arm seem to have been the culprit. Has anyone seen heim joint sway bar links for GMT900s?
Korbin_A
