I installed a avic-8200nex with idatalink gm5 but cant get calls to work
UATahoe
Is it just the opening that needs to be trimmed?
I haven't yet. I never understood crutchfields position on why it wouldn't fit. They said it was because the screen pivots down and out but when I explained that my factory nav does that already they just said we'll try it then. Kind of poor service but oh well. From reading though it just seems like light sanding of the dash kit allows everything to work just fine. I hope to have it installed soon. I am trying to figure out which double din kit looks and fits the best. Seems like there are great and horrible reviews of every kit out there. Lol
calsdad
Crotchfield lists the Pioneer AVIC-5200NEX & the AVIC-6200NEX as fitting my 2010 Yukon XL - which should mean they will fit all the GMT900 trucks with the center dash console. I cross referenced the dimensions of the head units for the 5200, the 6200 and the 8200 - and they're all the same except for the fold out front panel on the 8200 and the 8200 also needs 3/4" clearance in the back vs the other two which need 3/8".
From what I read earlier in this thread - it seems like a couple of people have gotten the 8200 to fit - so is Crutchfield maybe operating under a "if it doesn't just slide right in with no mods - then it doesn't fit" set of rules?
If all I have to do is sand down the edge on the front of the Scosche mounting bezel and maybe do a little cutting on the back for clearances - I don't see what the big deal is. I haven't yet taken the dash apart - so I'm just trying to figure out as much as I can ahead of time so I can hopefully get the install all done in one shot.
93blkongreenpro
Its in this thread somewhere what needs to be trimmed. I havnt had time to pull mine out to take my dremel to it
Sent from my SM-G935P using Tapatalk
Meccanoble
Georgia
The Scoche brand doesnt need any modification from what I read. It can be ordered online.
sabasigh
Correct, I replaced the metra mount kit from crutchfield with the scosche unit and faceplate has perfect clearance for lowering and removing.
bacin87
bacin87
San Francisco, Ca
It doesnt technically fit. I have to grab the bottom lip of the screen to get it to slide down and push it to get it to go back up.
Someone said the kit can be trimmed so that it moves smoothly.
I dont open it much bc I use the 128gb sd card for movies and inuse my usb for music and Android/Apple auto, so that does not phase me.
i didn't have to trim my kit or force the radio closed. there is a small plastic lip on the back wall of the radio bay, you should see an opening in the back of the bay and plastic lip in the middle. the wire harness, hdmi and usb cable pushes up against the plastic lip if you remove the plastic lip the harness can sit in the opening and the radio will sit flush. I did this and my radio is flush and opens with ease. I also used a Scosche Dash Kit for 2006 - Up Chevy Impala / Tahoe mount bout from amazon. I linked it for convince.
calsdad
Excellent - thanks for the info. I'll be getting the Scosche mount kit then.
grmarco
Maine
Have any of you guys had any issue with the rear ent. (flip down) and using the dual zone...The guys at "Buy Best" say I can't use the dual zone without headphones. What I want to do, and think I can, is set the front to play music and let the kids have a DVD in and have audio in the back. It does work at this point but only with the infrared headphones....So I am a bit confused. I cannont get it to play through the 'rear speakers only' when it comes to a disc. But if I put the DVD on and the change the front zone to sirius or radio or whatever, the sound will come out through the heaphones. I think they did not wire it correctly or have a set of RCA's mixed up...what do you think?
I have a 2010 LTZ with the Premium Bose, rear seat flip down, and they put in a Pioneer 4200 NEX head unit (only upgrade to the system) with the Meastro RR and GM5+. I also do not get engine codes or any 'HVAC' screens. Only the Guages, and battery voltage. Does this sound right?
Any advice would be appreciated.
Tony
93blkongreenpro
Tony
Idk of it will only play through thr rear speakers. I know it has a headphone out for rear audio and i hooked that up to my flip down for the ir headphones. When i play it through the radio, it comes through all speakers. I use the rear selection when i want to listen to something else while he has his headphones on.
I wished the rear selection worked at the same time as andriod auto
calsdad
So I finally had the time to get the AVIC-8200NEX installed into my 2010 Yukon this weekend. With the help from a few videos I found on Youtube (mostly around how to get the trim apart) - it was pretty straightforward. I took my time and got interrupted a few times but overall no big problems.
I decided to solder up the connections from the Pioneer 8200 harness to the iDataLink Maestro harness just so they'd be solid - and I didn't a soldering wand so I had to run out and get that.
There were just a few small issues I ran into. The first one was that the head unit obviously wasn't going to fit into the dash with enough space for the wires to fit in. After playing around with it a little - I figured that if I cut out some of the plastic at the back of the opening where the head unit goes in - it would probably have enough space to fit. I managed to cut away one side with a pair of wire cutters - and then I used a box-cutter to slot the plastic enough that I could bend it back and forth to break it off.
With that piece taken out - the head unit would sit flush against the front of the opening when it's mounted in the Scosche Dash Kit adapter.
I know some of the earlier posts here said their front panel would not open - but after getting the whole thing mounted up - I found that the front panel opens up with no issues at all on my unit with it mounted in the Scosche. There's a little bit of extra space top and bottom using the Scosche adapter - so I think if the front panel was sticking at all - I could likely adjust it and get it so the panel had enough clearance to open.
The clearance for getting the bundle of wires coming from the Maestro RR is still a bit tight - but I managed to get them all in there and I don't think anything is pinched.
Right now - everything is just sort of hanging under the dash for now. Once I get everything hooked up - I wanted to check the unit out and make sure it all was working properly. It appears to be mostly working - I found that the steering wheel controls and the gauge functionality - is not working at all.
I guess I've got to pull the thing out again tomorrow and see what the deal is with that. I'm wondering if I hooked something up wrong. It was sort of unclear to me which port I was supposed to plug the "D" audio cable into on the back of the Pioneer 8200 , and also the "H" Data Cable - first didn't really want to go into the plug on the Maestro module all that well - and then didn't seem to want to go into the plug on the back of the Pioneer head unit nicely either.
I'm wondering if one those two cables isn't plugged in correctly. The plug on the Maestro module for the Data cable actually looked like it might have been a little screwed up right out of the box.
calsdad
Hey Crutchfield is saying the 4200NEX won't fit cuz of the fold down face. They are saying the 6.2" displays are the ones that fit.
Thanks
Well Crutchfield is wrong - I just installed my 8200 today - and it fits (with a little cutting at the back of the mounting hole) - and the fold down face opens with no issues using the Scosche mounting setup.
93blkongreenpro
Well, that means that Crutchfield was in fact right, since you had to modify it to fit and function 100%.
calsdad
I suppose that depends on your point of view.
The first car stereo I installed was like 35 years ago - and I don't remember ever installing one where at least a little bit of modification was not needed. Crutchfield used to consider this when posting their "fit or doesn't fit" evaluations - and somewhere along the line they must have decided that if ANY modification at all was needed - then they consider it a "no fit".
I looked at the Crutchfield site before attempting to do this - and they don't appear to be considering this a "no fit" - because of the cutting. They portray it as a "no fit" - because the front panel won't fold out, but they recommend the Metra kit - and not the Scosche kit. And as a number of people in this thread have already noted - they also had problems with the fold-down front panel and the Metra kit.
I'd consider that a failure on Crutchfield's part for not taking that into account and accurately portraying the true fitment possiblities.
Meccanoble
Georgia
I bought a 4200nex and installed with no modification using the Scoche kit on Amazon.com. That kit works for various Chevy vehicles. Crutchfield was wrong if they say it doesnt fit.
calsdad
If I remember correctly Crutchfield specifies the Metra kit - which according to some of the previous posts on this thread, didn't allow the front panel to open.
Crutchfield is selling a service and promoting themselves as the experts in this stuff as far as fitment and all the details on getting a stereo installed, so when they say " it doesn't fit " when it obviously does if you use the correct adapter kit and do a little clearance work at the back of the dash opening - they're not really selling a very good service IMHO.
Crutchfield has been around for a long time - and I can remember using them to check fitment on previous vehicles I was considering installing aftermarket heat units into - and they would have info in there that cutting was required.
IMHO a little bit of cutting does not warrant a "does not fit" verdict.
"Does not fit" is when you're trying to install a double DIN head unit into the dashboard of a 1972 Chevelle or something like that. Or - like my 2006 Acura TL - the stereo/nav unit is so integrated into the dash that it's simply impossible to replace it with something else without doing extensive customization work.
calsdad
Oh yeah , the hidden bypass feature detailed in this video:
Seems to work perfectly. I was able to have the wife enter nav info while the vehicle was in motion when I took the truck out for a drive today.
Ob1hybrid
Are you guys running this on factory Bose speakers? What's the difference in sound quality and loudness on Bose factory speakers if that that's what your doing?.
Ob1hybrid
Ob1hybrid
I guess they're a litte picky when it comes to modifications.
calsdad
I still have the factory Bose speakers and amp. Honestly - I'm not sure if the sound is any different or not. I've got 52 year old ears - and I'm sure I'm partially deaf because of working in loud environments for so long. I also never used the CD on the factory radio (best source) .
I can say the Pioneer sounds pretty good to me, for whatever that is worth.
Hodmjstone
