Under hood light mod
ezdaar
Chat Troll
Redneck central, Aka Houston
Sit back with a beer, look at the oem conduits and think "where do the wires want to be, to completely hide?"
You will see the path rather quickly.
My #1 focus, is to make these blend in completely with OEM wire paths.
If its done right, even a die hard motor head wont be able to see any of the wires.
Other than the obvious one on the hood.
I have a ton of pics here. look closely and you will figure it all out.
Blue LED on my fuse box cover is the switch for mine.
The silver truck, is mine and was the first. lots of info in those pics.
Big Buttons
The SS Burb
South Texas
These are so bright I worked on my brothers car with them. Pics don't do these justice!
mals
Western Mass
I have not seen Doug around here lately.
Thanks. I checked after I posted that and saw that he hasn't logged in since February. Hopefully he'll drop by eventually, but either way I have several projects to get to before this would be on the top of the list.
mbp1979
North Little Rock
Does anyone know which led lights these are that are used? Are the bulbs or regular led strip that you can cut to length?
seven9st surfer
Milton, FL
Pretty sure it's the strip lighting that you can cut to length. Just make sure you get the waterproof type. I did the same thing with my truck, and it turned out great. I only added the lights under the hood, not by the firewall. I might go back and add it later, but it doesn't really need it
2015-12-15-18-45-52_1280x720-jpg.57824
2015-12-15-18-46-05_1280x720-jpg.57825
seven9st surfer
Milton, FL
I don't have a part number, I think it was just an off the shelf rocker switch from Autozone or something. I installed it on the backside of the fuse box.
about20ninj45
love this mod!!
TheAutumnWind
I still have some pics from dougs underhood lighting installs... this is an SS.
CTSV
silverado
Tahoewhat
Ballin' on a Budget
TX
Wow didn't know this got bumped. But I have let Doug know about this and he will be on soon.
That's my SS but y'all are missing my Tahoe. Worked with factory older nbs like 01 or so I think, hood light. I had no switches just open hood and lights. It worked with the older mercury swith hood light
Sent from my SM-G930T using Tapatalk
Tahoewhat
Ballin' on a Budget
TX
HeavyHoe03
