adventurenali92
Yeah. There's a product called gator grip, it's like the stuff used on skateboard decks. That would probably work.
Actually yes that's a good idea. My intro has spun off!Would you like this moved to the "Build" section?
There's several of those same headlight combos on EBay, different configurations as far as chrome w/ clear lens, black/clear, black/ smoke lens etc. Pretty decent projectors, and although some say they are Spyder brand they can't be retrofitted with TRS's Spyder kit. They work well with regular HID though. I would go with LED tails though, those ones look cheesy. If you go with smoke lenses be prepared to do a 55 watt HID or they will be dim. I have some info in my build thread.View attachment 65982 I can across this seller on eBay and for what I get, it looks like a lot of the light pairs I see on Amazon and other places for cheaper. With that many reviews it seams like a good deal. Anyone had experience with this seller?
Neither, you want the halos spliced into the park lights. The ones that come on when you turn the headlight switch to the first position, before you turn the actual headlights on.So just got the headlights and they look sweeeeeeet. Taillights were also included and look perfect. One question is which cables to splice into for halo effect power. The headlights or the drl cable? The halos won't work if the drls are on vice versa
