Just bought a 2016 Tahoe LTZ. Could use a little advice.
adrone
Hi,
I purchased a 2016 Tahoe LTZ about a month ago from the dealer here north of Atlanta GA. After taking it out on the freeway the first day I noticed it has a soft spot in the hood (an area about the size of a beach ball directly in front of driver) that moves violently once it has enough air pressure from speed 70+ mph.
I also noticed it vibrates badly with it being much worse over 70mph.
I took it back to the dealer next day where they sent me to their independent body shop. Body shop said the hood is defective and not bonded to the substructure correctly that I need to tell the service writer to order a new hood under warranty. They did not check the vibration that time. Service writer tells me she will call me once they have hood that I can bring it back and solve vibration and put the hood on at the same time.
Weeks go by the same service writer calls me on 4 separate occasions saying I have a recall on my vehicle but each time it is not for my vehicle but someone elses and each time she doesnt remember my previous visit or that she is supposed to call me about the hood until I remind her.
Finally out of frustration I bring the vehicle to them and drop it off. They call me two days later and tell me that the hood problem is normal that even the general managers Tahoe does the same thing and that they will not be fixing it. They also tell me that the vibration is normal that they put a "pico" meter in the vehicle and vibration is within spec up to 70mph.
I left the vehicle unhappy....called customer service where I was assigned a "Senior Advisor" (LOL) from Chevrolet. Who doesn't even leave his last name on emails and never leaves a way to contact him back.
I pick up the vehicle and took it to a tire shop where they Road Forced balanced the tires and 2 of them came back at a 35lb and a 37lb(weight required to make round) which is terrible beyond anyones spec. They could not balance the 37lb at all and the 35 they got down to 22.
Further they showed me that the "Bridgestone Duelers" are not even standard Bridgestones. They are labeled as a Spec tire that was made specifically for Chevy. They are much cheaper built than a standard Bridgestone Dueler according to the tire people.
Later the Chevy "Senior Advisor" finally calls and tells me everything on the vehicle is in spec no repairs will be made. I asked him how he arrived at that conclusion where he told me they put the vehicle on a Road Force Balancer at the Chevy dealer and it was within spec. I doubted that due to the tire shop report. I asked him if he even knew what motor was in my Tahoe and he did not.
I told him I had no documentation to show that it had been balanced or checked. He said doesn't matter it was done. I then call the Chevy dealer where the Dealer GM promptly sends me a copy of a service order where "Mark" the senior advisor had previously sent an order stating not to remove or attempt to balance as long as the "pico" meter was within spec.
So "Mark" my senior advisor from Chevrolet lied to me and got caught in his lie. I then called back and asked to speak to anyone else above him and they told me that was not possible that I must go through him. I finally had a message sent to someone higher up but never heard anything.
I have never experienced anything like this before from a company and I have no idea what I should do about any of this other than speak to an attorney maybe? The tires I could replace I suppose but the hood I don't know.
Chevrolet obviously has a policy of passing the buck, denial, deception and whatever it takes to save a dollar. They could obviously care less about the consumer.
I paid almost 70k for this Tahoe and I bought the most expensive additional warranty as well and I guess that means nothing.
Please let me know if any of you know who I can contact within the company if there is anyone within the company who gives a crap.
Broham
So Cal
I'm not so sure he's referring to the usual buffering/vibrations others have referred to in the past. This seems like he identified an issue, had it confirmed by a 3rd party body shop the dealer sent him to, the problem being the hood. There's absolutely no reason this shouldn't be replaced by warranty. I don't have any experience with legal action regarding a vehicle, but I would most definitely speak with an attorney and see if this is something they can help you with. I'd even go as far as getting another opinion from a different body shop and see if they too confirm it's the hood. This hopefully giving you more ammo when the battle starts up. Time is of the essence though, the longer you wait, the more they can point the finger at something else. Good luck
Sent from my SM-G925T using Tapatalk
Parthery
Atlanta, GA
Not sure who your dealer is as there are many north of Atlanta, but I have some thoughts...
1.) A good service department makes all the difference in the world. FWIW, when it comes to GM service - I use Autonation at North Point. I've developed relationships with them over the years and they have gone above and beyond for me more then once. Ask for Tim if you go there.
2.) I suggest you find another dealership, introduce yourself to the service manager, and go for a ride. Let him see the magnitude of the hood vibration and then see what his recommendations are.
3.) Assuming you bought the truck new, it will qualify for GA's lemon law. The details on the process can be found here:
http://consumer.georgia.gov/consumer-services/lemon-law-complaint-process
4.) There are known issues with Bridgestones and vibrations on the 22s....if they can't balance them out the easiest fix may be to replace the tires with something else. Some folks have had good luck with Michelins...or Continental. It's just a matter of again - finding a dealer that will deal with it.
Good luck.
A
adrone
Thanks for the info. This dealer is in Canton GA. As I said Ive never seen anything like this. This experience with the deception and lying to avoid having to spend even a small amount of money to make a vehicle right on the dealer and the Senior advisors part is beyond belief to me. I did purchase the Tahoe new from the dealer in question. I have bought over 500k in new vehicles from the salesman in 3 years(he worked at Ram previously). The salesman contacted the Manager on my behalf and their response was that they would fire him if he asked anything else or spoke to me again about this vehicle. He had to whisper next time I spoke to him as he was afraid soneone there would hear him.....
I am going to try another dealer this coming Tuesday that is in Jasper GA and see what they do but it looks like the orders not to replace or repair come from Chevrolet themselves (or they do according to the first dealer) so Im not sure if it will help. I hope you guys are right and they try to fix the Tahoe.
Either way after this experience I dont think I would ever buy a Chevy product again even if it was free. What happens if you have a major issue??
I only buy new vehicles so that I do not have to worry about repair or be involved in this kind of nightmare....Life is too short to be dragged through a bunch of nonsense by crooked people.
According to one lawyer I contacted the lemon law applies more towards failed attempts at repair rather than refusals to repair....Either way I am collecting the documentation and this will be the third time I have brought the vehicle in for the same issues on paper. I will then send the final attempt to repair letter and pursue the lemon law either way if they decide again not to do the right thing and fix the vehicle.
Theres always the idea of having a vinyl wrap made explaining my experience with the dealer and Chevy and pay one of my guys to drive around in an endless circle near the dealership....
Parthery
Atlanta, GA
The dealer doesn't want their salesperson to talk to you? Word of mouth is the best way to bring more business in.
I know now who the dealer is....I've heard from other people in the business that they have some "challenges". Try another dealer and see if you can't get it resolved. I think Day's is in Jasper...I've dealt with them in Acworth and they seem to be good people.
GM Customer Service
Michigan
Hello adrone,
We appreciate you reporting on this situation, and bringing it to our attention. This is not what we wish to hear, as it is important to us that all our customers have a positive experience with our products and our dealerships. We would be more than happy to discuss this situation further with you. Please send us a private message with your VIN, full contact information and involved dealership.
We hope to hear from you soon,
Julianne M.
GM Customer Care
ajs800
Michigan
Hello adrone,
Julianne M.
GM Customer Care
Julianne / GM Customer Care,
Any information regarding the buffeting issue with these new trucks? Was it addressed for 2017? It would be nice to hear from GM regarding the ongoing vibration/buffeting issue that they keep claiming to be "normal". There's a reason these models are racking up to be one of the most "bought back" vehicles.
GM Customer Service
Michigan
Good Afternoon ajs800,
We are sorry to hear that you are experiencing these concerns. Please be advised that our team does not have access to the necessary information, but the certified technicians at our GM Certified dealerships do. If you would like, our team could reach out to your dealership to answer any questions that you have. Please send us a private message that includes your VIN, current mileage, full contact information, and preferred dealership. Thank you and we look forward to hearing from you.
Philip J.
GM Customer Care
ajs800
Michigan
Thank you but I've been down that road a few times over the last 15mos with no real success, including working directly with a GM engineer. I'm hoping there ends up being a real fix and I don't have to buy new tires annyally and/or have them road forced routinely to keep from having the dreaded buffeting issues. Time will tell.
Ralph Varick
I have a new 2016 Tahoe with a vibration issue and the Dealer and GM say it is normal...GM is denying this issue ....It must be too expensive to fix...They should not be allowed to keep selling these defective trucks ...Where is the law and the press....
A
adrone
Hello adrone,
Julianne M.
GM Customer Care
Hi,
I was responding to your quote on the thread I have started regarding my 2016 Tahoe. My case number was xxxxxx
2016 Tahoe VIN#xxxxxxxxx
Once I attempted to confront the Senior Advisor "Mark" from your company on a direct lie he told about what was done or not done to my vehicle at Bill Holt Chevrolet with documentation sent to me from xxxxx to prove it "Mark" has never been reachable and has never contacted me back. I attempted to report this through the 1800 number and I was forwaded to a guy named "Christian" who is supposedly his supervisor. I have never been able to reach Christian, never given a direct number, and I have never been contacted again by Chevrolet concerning this issue. I have been left with a defective vehicle and zero customer service other than quite a bit of deception, denial, and attempted manipulations both on the dealers part and that of the Senior Advisor. The dealer ended up coming clean and providing me documentation on Chevrolets orders not to even attempt to properly diagnose or repair issues with the vehicle.
Please feel free to contact me to discuss this in detail.
Please be aware that I fully intend on publicly posting any relevant communications from Chevrolet on this forum and elsewhere and I will not stop there.
Before you consider my rhetoric contemptuous please understand I bought a new 70k vehicle and even purchased your highest available warranty and thus far it is ridiculous and insulting how I have been treated.
Regards,
xxxxx
Im not sure if I can put detailed info on the forum guys so Im removing it but heres the message I sent to Chevy on this forum after reading her response. I will let you know if they actually do contact me back and what the result is....its probably just more smoke and mirrors.
A
adrone
Ralph,
Take the vehicle and have it road force balanced at a good tire shop. Mine has the 22" rims and I know from other vehicles that unless everything is just right a vehicle will always have some vibration on 22's.
Turned out the vibration on mine is definitely from factory defective tires that are out of round. If a vehicles tires dont run round at probably 10lbs of force or less (pressure applied while spinning to make the tire round) then it will definitely have vibration on 22"rims.
My numbers on the new Tahoe were 37lbs, 35lbs, 12lbs, and 6lbs. In other words only one of my tires was good. The other fair but could vibrate, and then the other two so bad they are impossible to balance properly.....
Shame I had to go to tire shops to even figure this out that Chevy refused to even check.......NORMAL yeah right.
lynxnova
New Jersey
I had a problem with my old truck a few years back where the dealership completely ignored any of my concerns... I emailed the president and cc all of the VP and everyone in corporate headquarters in Detroit regarding my matter and it being unresolved... within a day or 2, I received a phone call from a vp.. she asked for the dealerships name and I gave her all the info of the dealership including names of all the sales manager and service managers.... within one week all my problems were resolved by the same dealership....... in a nut shell... no dealership likes to get phone calls or get reprimanded by corporate headquarters over a simple fix... try it and you will see how fast they will fix things...
Sent from my SM-N910V using Tapatalk
A
adrone
This is Chevys response thus far...another false claim:
Hello Allen,
Thank you for updating us with your information. Please know, it is important to us that you have a positive experience with our products and dealerships, and regret to hear that this has not been the case. We apologize for any frustration, and understand your desires to have this situation addressed.
We were able to locate your case within our systems, and see that your agent. Mark , is still diligently working your case. He has been continually reaching out to the dealership to discuss the details of the diagnosis on your Tahoe. He plans on reaching back out to you as soon as he gathers any new information. I will let him know that you wish to be contacted as soon as possible, and notify him of our interactions.
After researching your case in depth, I do see that your dealership is in touch with one of our specialty teams within GM. At this time they are looking into exhausting all possible resources to provide you the assistance you need.
All the best,
Julianne M.
A
adrone
Im posting this stuff so you guys can see what nightmare and smoke and mirrors are in store for you if you purchase a new Chevrolet and have issues. They appear to be all about denial and deceptions....with a smile
Here is my response:
Juianne,
With all due to respect what you are stating is very far from accurate. "Mark" who you say is working on my case lied to me directly about what was done to my vehicle and has not responded or had involvement with my case since I have confronted Chevrolet about the dishonesty. I have heard nothing since then from Chevrolet and according to the dealer what you are saying is not correct. I have since taken my vehicle to another Chevrolet dealer where they are inspecting the vehicle.
You are claiming that Chevrolet or "Mark" is working with the original dealer in question??? If that is the case please be specific as to what is being discussed or done about this problem and/or provide me documentation to support that. Every time Chevrolet makes a false statement as it would appear that you are making now in the interest of saving face it insults my intelligence and lowers my opinion of your corporation.
Please feel free to have someone from the company who has the authority to do something to solve this situation and reprimand "Mark" contact me to avoid future bad
A
adrone
I have written no less than 10 letters and been back and forth to dealerships and mechanics since I bought this Tahoe around a month ago.....to the point of mounting gopro cameras to the dash and hood to show whats going on with it.
Thus far Chevrolet on each occasion from every angle shows nothing except for deception...layer upon layer of deception with zero intention so far of even attempting to examine and fix the problems with my vehicle. Learn the easy way by watching what I and others go through dont go down this road yourself.
WCDENALI
Adrone,
Thank you for your posts. From someone that has been in your shoes, I understand and know your frustration. For a year and half I dealt with the numerous issues on my 2015 Tahoe. To make matters worse, GM was no help and left me wondering how and why GM has such horrible customer service. Like you, I dealt with the lies and deception from GM customer service. In my case, "Jason" and his boss "Corwin" lied to me several times regarding several issues during my repurchase of the 2015 Tahoe. When I called them on their lies, I was hung up on and neither one would answer or return my calls. Great customer service right?
Keep pushing the issue and hopefully GM will make things right. Good luck!
2manycars4me
Warrick County, IN
I went through a situation like this with a 2009 CTSV. Talk about lies and deception. I'd get a call from the Executive council person with one story and already have the real story from my service advisor. I was told one time a GM engineer was there looking at the car and diagnosing what was wrong. Only problem was the car wasn't at the dealership anymore. I had all sorts of lies and untruths spread about the car. The dealership did not push to get it fixed and when it was finally done, the job looked like something out of a horror show instead of a Cadillac dealership. I swore I'd never go back to GM. Owned 2 BMW's and had fun with them. If the dealership in town was worth a crap I'd still have the BMW. I bought an SS because it was made in Australia and was untouched by the idiots on our side of GM. If it would have been an auto I'd still would have it. Traded for the Denali and I think I've got a good one, a crappy dealer again but a good truck. I drive 40 minutes to a different dealer so I don't have the BS from the selling place. Good luck with the repairs, write Mary an email and maybe a good executive council person will help. Hope you don't get Igor, he lies real good.
Eickybobby5050
