Lil_Stump
Brunswick, GA
Finally got my lift done on my '07 ltz. Went with the RC 3.5" kit, which I'm fairly surprised with, seems to be better quality than I thought, and still rides just as good as it did before. Will post pictures later when I can get some. Did get a chance to measure the fender heights though, and found the front to be 40 1/2" and the rear to be 41 1/2".
redeknightjr
Recieved my Beltech "2 drop spindles. I will be installing them, new hubs, front swaybar bushings, and endlinks tomorrow
1SG Retired
kchawaii
By chance when you installed the puddle lights were you parked in daylight? Put a book or magazine over the sun load sensor on the dash to trick bcm into thinking it's dark, then using your key fob unlock to turn on the perimeter lighting to install them so you can get the polarity right.
Sent from my SM-N920V using Tapatalk
I didn't even think about that, but it was dark enough because the stock bulb was coming on. Thanks
redeknightjr
1SG Retired
Installed beltech 2511 2" drop spindles, moog swaybar endlinks, and new hubs. The factory endlinks were a beast to remove. They were weld rusted. It took me about 25-30 mins per. I noticed at full turn now there is rubbing occasionally. I have the adjustable beltech street performance shocks with 4 spacers per the instructions for factory height.
1SG Retired
aflumb
Las Vegas
well got back from the deployment to find that the wife had blew up one of the airbags on the truck so and new set of TBSS rear air shocks on order, also installed the cabin air filter retro kit in. here next week will be a full detail
aflumb
Las Vegas
well my day continues with the Tahoe. After driving it i noticed it was shifting and driving kinda funny.
Well changed the oil, trans fluid (should have done this when i pull the 11K trailer across the country) it was pretty bad. Replaced the front end links, added the 1in spacer to the rear drop and installed the short bump stops that came with the drop from Tony. makes a big difference with the spacer and smaller bump stops. Cant wait till the TBSS air springs get in to try them!
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
That sounds exceptional. What were the numbers? (traction understood)
aflumb
Las Vegas
Full interior detail. Found the first dash crack. Was hoping it wouldn't happen.
sumo
rhode island
Was light on the throttle. Apparently if I'm not boosting, I'm getting really good mpg @60 mph level roads. Blackbear tune Afm delete
Was actually yesterday, but I finally washed that dirty Hoe. Embarrassingly, I can't even remember the last time I washed it and if I did, it was through an automatic one. About the only time it comes outta the shop is to load up the family then it gets it's dirty ass parked right back in there.
justinesky
Changed my motor mount in the escalade. It was not a treat. took about an hour 30. hope i dont have to do that again for a long time.
moto
