992dr
Eastern N.C.
Finally installed some new headlights. OE GM headlights.
992dr
Eastern N.C.
Now all I have to do is clean this pig. Driving soo much lately.
Choo Choo,
I've cleaned mine at least three times. I was never satisfied with the results, they were just too faded to save.
Mecc,
These are standard OE replacements. Are talking about retrofitting projectors?
I'm gathering parts to do a retrofit over the winter, hopefully. There are a few threads on here about them.
Stainless and beautiful TIG work- nice! Similarly, this is my vice left over from my Jeep days:
Since my XJ wasn't set up to climb and crawl like everyone else's, I was basically the mobile fab/repair shop that stayed on the access paths following the rock trails to be at the ready for anyone in need. I carried spare parts, tools/equipment, first aid supplies, fuel, water, etc. This vice was one of my quickly thrown-together ideas for trail use.
992dr
Eastern N.C.
Thanks guys, I appreciate the kind words.
Believe it or not, that was all laid out and drilled by hand. 1/2" SS angle and 3/16" SS tubing.
iamdub,
Nice man. Hey, if you weren't there they weren't there ;)
That's going to be my next project to make a mount for a vise.
redeknightjr
Blackbear tune update with Justin. He is very personable, professional, and cool as a cucumber. Thank you again Justin. Always a pleasure.
1SG Retired
NGAneer
NWGA
Soon as I get a chance I will do a write up it was a lot of cutting and modifying to really get it to fit just right
Did you remove the tow hook surround and they center "cover"? Can't quite tell from the pic. A closer look at the cutting and the mounting would do for me. Thanks.
HoS
G1 by jdm astar. They have a g8 now.
Research it a bit.
Sent from my SAMSUNG-SM-G935A using Tapatalk
osiris94ej
Casper Wyoming
I had the same problem with mines. The 194 LED's didn't work even after turning them 180. They worked fine for license plate bulbs, but nothing in the mirrors. Put the stock ones back in.
Replaced my puddle lights with leds. They don't work even when I reverse the bulbs. Even the original ones didn't work after a while.
By chance when you installed the puddle lights were you parked in daylight? Put a book or magazine over the sun load sensor on the dash to trick bcm into thinking it's dark, then using your key fob unlock to turn on the perimeter lighting to install them so you can get the polarity right.
Sent from my SM-N920V using Tapatalk
agupta3224
Pic of led head lights.
Is this on Yukon or Tahoe? Did you use standard housing? It does not look like there is a scatter, but just want to make sure that there is no scatter in the beam?
fiatdale
Houstons Best
Houston
Somehow stumbled across these. No I did not do this to my GMT900, but not sure where else to post. Not bad looking:
HoS
2007 yukon xl Denali
Stock housing.
You can adjust the beam to match the current bulb to help fix that.
bigrhino
l.e.s manhattan,nyc
Thanks for the info.
08HoeCD
Replaced a bad window switch in rear driver-side door. Easiest & quickest repair ever.
vsaravia
