NORCAL SS 3/5-6 ON Deanli with 24s
bagged00
So how do you achieve 3"? Keys all the way turned down? Also how does LCA work with drop keys?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
do not use keys. more than 1 inch they start to ride worse and worse. at 2 inches camber off and wont align and lower than that worse it gets. the a arms is what lowers the truck 3 inches reindexs keys and ride stays nice
Trashcan
Real nice how low are you ?
How’s the ride quality on that? Looks good. I wanted to go 2/4. But now I’m thinking of doing the 3-5/6. Is it still AWD? And are you still using factory air ride? I don’t want any error messages on my dash.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
My set up 3/5-6 rides good. Awd is no issue but my set up bypasses autoride and no message on dash
DDenali
Orangeburg, SC
Looking at that 3/5-6 drop has me second guessing my visions since thatll be a little lower than I want. So I'll probably go with a 2/3-4 drop that should be sufficient enough to eliminate the hidious gap. Tony any ideas for the my setup. I want the best solution.06b0edaf84871bb618a523ea4222b090.jpg
Sent from my SM-N950U using Tapatalk
Da90
Tulsa, OK
Not a Denali... I have a 3/4 drop currently. Sometime soon I will end up getting 6” springs. It’s just not low enough! Also stay away from drop keys! The ride using keys is why I bought Tony’s kit.
golavaman
