Stolen and Recovered 2012 Escalade Premium (re)build thread
J
Jmccormick
Your truck was likely stolen to make somebodys 07 into a platnium. They likely swapped suspension also so make sure you order the struts by vin. If they recovered the vehicle mostly in tact the previos owner was likely paid out on a comprehensive vandalism claim hence the clean title. Do you mind discussing your buffing process? Truck looks amazing.
I think you are correct, I just think it's odd they took the time to install the cheaper older parts from another Escalade. If I were to steal this truck to make my older Escalade look new I sure as hell wouldn't take to the time to swap parts I would just steal the shit and ditch the truck somewhere lol.
J
Jmccormick
As far as buffing techniques, it varied panel to panel.
The passenger side was pretty bad.
My go to combo is Meguiars M105 and M205. It's a pretty user friendly combo, 105 takes out most of the scratches and 205 takes out the scratches 105 put in the paint to get the deeper stuff out.
I used a Torq 10FX Dual Action polisher in the small areas and the Torq 22D Dual Action polisher for the large open areas on the truck.
M105 with an Orange pad followed by M205 on a Green pad corrected the paint about 85% which is fine for a daily driver. I then followed that up with Chemical Guys Black Light Hybrid Radiant Finish on a blue pad. The black light really made the paint look wet. Then I followed that with Sonax Polymer Net Shield for sealant.
The tail gate was extremely rough,
I did M105 on a yellow heavy cut pad, followed by 205 on a orange pad, then 205 on a green pad.
Hood was extremely messed up.
3000 grit wet sand on my Torq 22d, followed by M105 Orange pad, M205 Green pad, Black light, sonax.
Hope this helps, every paint job is different.
There are a lot more Compounds out there that work better than the megs stuff, I didn't care, this is a daily driver. You can also snag the 105/205 combo at your local autozone.
Batterycap
I just put in roadworthy shape a 2001 Suburban. It was of course a far larger task than I imagined. After all of that, I still take my hat off to you. You sir - have patience to spare.
J
Jmccormick
Hey thanks!
It's surely coming along finally.
I am headed out to the garage to finish polishing the passenger doors and fender.. last coat of Sonax Polymer Netshield. Then I am hoping to have my front struts ordered this week.
I did find a 12-14 Premium/platinum bumper assembly locally for a decent price. I just cant justify it at the moment. Maybe down the road they'll still be out there.
tgui
I use the same pads and 105/205 combo on all my cars, two of which are black. It always turns out quite nice.
I don't use a wax though, Klasse sealant only. I can forgo a bit of shine for longevity.
08grey
If it was a planned strip they probably did it so they could drive it out the garage after. Then park it somewhere with a wheel missing so the cops take notice.
Sent from my iPad using Tapatalk Pro
J
Jmccormick
Were did u find the rear bumper?
I drove down to Indiana to a salvage yard that had 1 surplus rear bumper assembly left.
They got it from GM, left over from final assembly.
It was a great deal at the time, $850.00 Rear bumper cover, step pad, chrome strip, sensors, harness, and both exhaust tips and already painted OEM black. I priced everything out individually and it was well over $1500 plus paint at the time.
J
Jmccormick
I wrapped up the buffing last night.
I removed the door handles real quick to get up close and tight. I also had to remove the mountain of caked on white wax from the previous dill weed "detail" shop.
Finished!
Very pleased with the results, I still need to seal the rear bumper but I ran out of microfiber towels.
I also swapped the license plate bulbs to LED to match the rest of the vehicle. I plan to swap the reverse lights and under mirror approach lights to LED as well.
I am going to clean the interior up next, and drive it for the winter.
J
Jmccormick
If anyone has black door handles laying around i would really like a set!
J
Jmccormick
Pulled it outside for a quick picture!
I fixed the fog lights too! they haven't worked for years. A little digging resulted in my finding the fog relay to be missing. kind of random but I am happy it was a $5 fix!
Friend gave me his Front door handles off of his 2013 Sierra for $20, now to find the rear handles.
Very happy with how the truck has turned out so far. I am also WAY under budget which never happens in car world or escalade world for that matter!
Thanks for the replies and hi fives.
J
Jmccormick
Ordered my AC Delco (BWI) OEM Front magnetic ride struts!
If anyone has been putting off the strut replacement on their Z95 Magnetic ride truck now would be the time to do so!
Amazon just dropped the price from $250 (already a good deal) to $195 for the fronts.
https://www.amazon.com/dp/B00EDQ14DE
Dealer wants $450+ each.
J
Jmccormick
Got home from work this morning, my other two door handles I purchased off of ebay showed up along with my new front struts.
Swapped the handles real quick and was super pleased with the result.
I went over to my dads house (next door lol) and used the lift to make quick work of front strut replacement.
2 hours later, struts are swapped. They were both 100% seized. All of the oil was blown out of them too. Truck literally drove like a dump truck. After swapping the struts it rides like a caddy again and I am very happy.
I am going to enjoy the truck now for the time being. Spring time will bring lowered suspension and new wheels are tires.
I am also working on ditching the wood grain interior to something a little more sportier.
Thanks for the hi fives!
BadDaddy2003
