Had to have the rear main seal replaced earlier in the week.....
agupta3224
Working on a LED project. Coming along very slowly. Also upgrading from DL8 to DL3 without Window Switches.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Finished installing stoptech rotors, caliper and pads with goodridge SS lines
^^^ Cryo-tempered rotors? I had some "frozen" Powerslot rotors on my S10. As hard as I was on them, I could NOT warp them and never once experienced brake fade. Always ran Hawk HPS pads. I'm glad there are cryo-tempered rotor options for these trucks cuz I will surely get them.
sumo
rhode island
Yea cryo. I had to wait 1 month due to back order of the rr rotor on top of where I bought from sent me the wrong side. 1st time they sent me all but the rr rotor, and didn't send the front pads. Also the delivery that day they delivered to the wrong house. Next door neighbor is like 70 and she said she thought she was going to need a hip replacement when she tried to pick up the boxes
I'm using power stop pads. The braking is amazing. There literally no brake pedal travel. Really firm. The feeling is like pumping your brakes with the truck off to the point were there's no travel anymore.
Sounds like my S10 after I installed hydraboost! Thanks for the feedback. You mind divulging from where you got your parts from? I saw a lot of suppliers with about $40 in price range differences. Running the Stoptech part number returns PowerSlot and even Centric parts. Maybe Powerslot is the parent company?
To remain on subject- I took my Tahoe and small trailer to get 6 square bales of hay for the girls to make a fall/Halloween display on the front porch.
sumo
rhode island
Centric parts is the parent company. I bought from autopartsanything.com I asked the rep when i ordered stop tech pads and received centric pads. Check out stop tech site and its even states stop is their high performance and racing line
NGAneer
NWGA
I've got a corvette 2nd servo and I'm considering a billet 4th servo. I think my truck could use it because it's pretty sluggish on the interstate when cruising in OD (mostly because of larger, heavier tires). I know most have said that you won't feel much difference unless you're towing/hauling. I'm also looking back on my corvette 2nd install and wondering if I should've switched to a corvette return spring also. So, help me out here...
Is there a gain to be had from a corvette return spring? Anyone with real world experience with a billet 4th gear servo (i.e. Superior K034)? Thanks for the help in advance.
redeknightjr
Did you remove the tow hook surround and they center "cover"? Can't quite tell from the pic. A closer look at the cutting and the mounting would do for me. Thanks.
The cover mounts over the tow hook brother. It just snaps and clips on
1SG Retired
63Blackseries
Canada
Headlights look great I like the light tube design but the projector output, you guys think it's as good as mini h1 retrofit?
johnsonwillie199
