Level My Denali Xl
Bigjimmy
Looking for a bit of advice on Levelling my 2008 Yukon Denali XL AWD
The Autoride shocks are shot so want to go to standard shocks, also want to level the front to fit 33" tyres
So..... Anyone fitted Rancho RS999928 front Spring/shock combo to lift front 2"?
Also what rear shocks would be recommended after I've removed fuse to disable Autoride and removed electronic shocks ?
I'm all the way over in Scotland so I need to get this right first time round!
Appreciate any help
PS
My last tank of gas was £120 ($160) fuel tax is crazy over here
01Konvict
Boats n Hoes
Raleigh/SML
Haha I will chime in to help mate. You got one big ass car for Scotland!
Don't get the rancho shocks. Get bilstein 5100 front and rear with eBay level kit prefer lower strut spacer. Don't go over 2.5" front lift. I prefer a 2" unless getting new UCAs. Rear add 1" spacer from eBay. Need to do more than pull fuse. You will need resistors on each shock line and remove all ride height rod sensors.
Bigjimmy
Bigjimmy
Many thanks Wade,just came across those bilsteins you've recommended on another site.
You can buy height adjustable 5100's max lift of 1.75" on front which should level it out perfect and give me room for 33" tyres I think?
275/60/20 BFG All Terrains would be my choice of tyre but not available over here,need to ship them in at,gulp ...$435 each oh dear me.
Got the Airaid intake tube on its way and a local tuner to install Blackbear tune once it's fitted
Cheers for info on resistors etc as well,much appreciated,3.9 Ohm I get get easily enough
And you're right it is one big ass car for Scotland and not cheap to run thanks to our crazy fuel taxes-(for every £1 spent on gas 80% goes to government!)but I love it's comfort,space(I'm a big guy and no lightweight) and the sound of that 6.2
bzubke1
DFW, TX
I recently did the autoride conversion to standard shocks with Bilstein 5100s on all 4 corners. On top of the shocks and bypass resistors you will also want to get new rear coil springs. From my understanding the coil springs that come on the autoride trucks are too soft for use with standard shocks especially if you do any towing. I got the Moog rear springs that are made for the z71s I believe part #81069 and it gave me about an inch of lift in the rear. Which is perfect for the ccm 2.5" front spacer I'm running. The rear of the truck sits 1/4" higher than the front.
Bigjimmy
Bigjimmy
Thanks for chipping in,don't plan to do any towing,trailers been sold and don't want to lift the rear just level the front out to fit 33"s
If the rear gets a bit saggy(there's a wife joke in there somewhere) I can fit some airbag helpers
You guys don't know how lucky you are with parts availability,it's not easy over here in the UK.Coming to Florida in December,think my flight luggage allowance will all be car parts......
01Konvict
Boats n Hoes
Raleigh/SML
Avoid the VAT and use luggage hahaha! Get bilstein but do a lower 2.5 strut spacer with z71 springs. Maybe add a rear spacer if needed. Could keep rear coils and add 1" spacer but I think spring rates are different for autoride shocks. If you set the 5100s at max setting it preloads the front spring some. I prefer a spacer and keep preload down for better ride.
Bigjimmy
Bigjimmy
Ok thanks for all the info guys,just need to get the parts halfway round the world and get on with it....
Can't even buy the bilsteins off the shelf over here!Going to have to get all of it from the US
davidl13
I have a 2012 Yukon xl Denali w z55 auto ride...
I added CCM 2.5" front and 1" rear to level... (Original shocks front and rear)
The back sagged so I added another 1" to the rear (2" total)
Looks much better...
I currently have 265/70/17 hankook Dynamo E rated... I need e rated because I drive 10 miles of high speed gravel round trip to my house... Anything less than E rated punctures tires...
Next tire replacement I will move up to 295/70/17 or 315/70/17.. Not sure if the 315 will fit
MichaelSE
2010 2500
Tucson
Post some pics!
davidl13
davidl13
The 1" leveling in the rear sagged, looked Ike there was something wrong.. I can't find any pictures of it...
Jonah52
Senor ******
Cleveland
^same experience i had. 2.5 front and 1.5 rear, never loved right and drove me crazy went to a 2 and she was good to go
MichaelSE
2010 2500
Tucson
Your Denali looks great, def one of the best offroad-focused Yukons I've seen. Who makes that roof rack?
I'm having the same issue with the rear on my LTZ, I put in a 2/1 level and the rear is still lower. I'm going to extend the air ride rods to see if the compressor can bring it back up, but will probably also end up going with a 1.5 or 2" spacer. Did you notice any ride quality difference between the 1" and the 2" spacer?
davidl13
Thanks, No ride quality difference, it is just another 1" spacer added, so nothing changes except it doesn't look sad anymore... Ha
I also added timbren progressive bump stops..front and rear. I was overloaded fully packed by about 10% gvwr (700- 800lbs) and the timbrens really tightened things up...
http://timbren.com/timbren-ses/
I also added Wagner ceramic hybrid brake pads, and that helped a lot with stopping power loaded down..
The roof rack is a rhino rack pioneer 107x58
http://www.rhinorack.com/en-us/prod...pioneer-platform-107-x-58-unassembled_42105bf
On the driver side I have 200w of solar and an awning, on the passenger I have a Yakima box and in the rear across the back I have 4 max trax for getting unstuck...
The solar powers a second battery under the hood (both batteries are odyssey AGM) In the back I have a full cargo slide and an ARB 84qt refrigerator.
If anyone is interested in more details of the build, I'd be happy to explain in detail, I made my share of mistakes on the learning curve, so I'd be happy to save you the trouble...
Jaron Hasley
Can someone post the part # for the 5100 Bilsteins. I just want to make sure and get the right set. Everything says it wont fit because of autoride, but they just bolt right on correct? These are the part #'s I found, Bilstein # 24-186940 Front Shocks, 46mm | 2 - Bilstein # 24-187237 Rear Shocks, 46mm.
And then I was going to get the moog #81069 for the rear springs.
Conedaddy
