2016 Z71 Tahoe 2" level on 285/55r20
Jareth Todd
2" front level
20x9 Fuel Maverick
285/55r20 Toyo R/T
2016YUKONSLT
Looks Good. Laura Buick just had a white Yukon with these same rims, but with 305/55r20.
Jareth Todd
Jareth Todd
I think that's just how the angle looks in the picture. In person it looks to be completely level. Maybe a 1/4" higher in the back.
Illnasty
New Jersey
I'm thinking about leveling mine out as well. Is it just a preference to either drop the back or lift the front? I would think lifting the front would be better so I get some more ground clearance.
Denton
Waco, Texas
Good, so if a 305/55 will work, then a 285/60 should as well. (33.2" vs 33.4")
Denton
Waco, Texas
My 305/55 have a slight rub at full lock in reverse, but since the 285 would be skinnier they might work...
Looks good, I am torn between a 305/55/R20 Mickey Thompson or the 285/60R20 Goodyear Duratrac. I got 63k miles and still going on my Mickeys, so I am partial to them but they dont make the 285/60r20 and only can find a Duratac in that size. Decisions, Decisions..........
Denton
Waco, Texas
Yep, 305/55r20 2.25" ProComp Leveling Kit
Do you think a 275/60R20 would fit with your setup? I have your exact vehicle, You have a 2.25" leveling kit, I am installing a 2.5" leveling kit. I am trying to stay with Mickey Thompsons, and wondering if a tire .7" taller, two inches narrower than yours, would fit? Any thoughts?
mowrer7
Southern Illinois
A 275 should definitely fit as it is shorter by .2" as for the 285 I believe it would fit with the same rubbing I have now. Let us know how it turns out.
Jareth Todd
Jareth Todd
I am looking at installing this exact wheel and tire combo. I am coming from factory 22" rims. How is the ride on Toyo's. I am debating the Toyo's vs the new BFG's. Thanks
The RT isnt as quiet as people have said. Unless you just want the aggressive look of the MT or RT go with the AT2. The ride with the RT is smooth not rough at all. Not a loud roar but they do hum a good a bit. Ive used Toyo's for awhile and from my experience I won't use another brand. Best out there in my opinion.
whitlecj
Thanks!
BradzTahoeStuff
View attachment 65924 View attachment 65925
During the leveling process, did you get any feedback about kits that level from the top or bottom or both? Some kits seem to level by adjusting at the top of the strut, others level by adding a bit at the top and the bottom of the strut. Does it matter much? Any significant difference in performance or stress on the CV joint and shaft?
I could be way over thinking this, but it did catch my attention.
Thoughts?
Merch619
