Jareth Todd
- Joined
- Dec 30, 2015
- Posts
- 18
- Reaction score
- 18
20x9 Fuel Maverick
285/55r20 Toyo R/T
Looks Good. Laura Buick just had a white Yukon with these same rims, but with 305/55r20.
Good, so if a 305/55 will work, then a 285/60 should as well. (33.2" vs 33.4")
Did you just get that? I was eyeballing those rims, trying to decide which direction i want to go with the Yukon.
Looks good, I am torn between a 305/55/R20 Mickey Thompson or the 285/60R20 Goodyear Duratrac. I got 63k miles and still going on my Mickeys, so I am partial to them but they dont make the 285/60r20 and only can find a Duratac in that size. Decisions, Decisions..........My 305/55 have a slight rub at full lock in reverse, but since the 285 would be skinnier they might work...
Do you think a 275/60R20 would fit with your setup? I have your exact vehicle, You have a 2.25" leveling kit, I am installing a 2.5" leveling kit. I am trying to stay with Mickey Thompsons, and wondering if a tire .7" taller, two inches narrower than yours, would fit? Any thoughts?
Yep, had it a lil over a week, loving it.
Where are you at in Southern IL?
The RT isnt as quiet as people have said. Unless you just want the aggressive look of the MT or RT go with the AT2. The ride with the RT is smooth not rough at all. Not a loud roar but they do hum a good a bit. Ive used Toyo's for awhile and from my experience I won't use another brand. Best out there in my opinion.I am looking at installing this exact wheel and tire combo. I am coming from factory 22" rims. How is the ride on Toyo's. I am debating the Toyo's vs the new BFG's. Thanks
Thanks!The RT isnt as quiet as people have said. Unless you just want the aggressive look of the MT or RT go with the AT2. The ride with the RT is smooth not rough at all. Not a loud roar but they do hum a good a bit. Ive used Toyo's for awhile and from my experience I won't use another brand. Best out there in my opinion.
A 275 should definitely fit as it is shorter by .2" as for the 285 I believe it would fit with the same rubbing I have now. Let us know how it turns out.
View attachment 65924 View attachment 65925
