ScottyBoy
Shreveport, La
That sucks to hear. Sounds like everyone this summer is already having big problems with their NBS Chevy's or GMC. Were there any indicators that your water pump is going out?
Sent from my SM-N910T using Tapatalk
Yeah, I've never had so damn many problems with my truck EVER until this summer. I've had to do a few repairs here and there over the years since I bought it back in 2006. But I've never had so much stuff seem to fail all at once. Since I bought my Suburban in 2006, I have had to have the rear end rebuilt (twice now, once in 2008 and again in 2013), the transmission rebuilt 2013, replaced the AC compressor in 2010, replaced all four brake pads and rotors back in 2010, been through three batteries now since 06, 3 sets of belts, just bought my 3rd set of tires, new shocks, I replaced my water pump in 2012 (and it is as easy as everyone says), replaced 3 window motors over the years...
But just in the last 2 months, I've had to replace two window motors (that were previously replaced with used regulator/motor assemblies), replaced rear shocks, brake pads, caliper bolts, brake hoses, knock sensors and harness, new headlights, and now my damn fuel pump just failed two days ago. I don't even have the money for a fuel pump right now because I just bought so many other parts recently, so I'm trying to sell some extra truck parts to scrape up the money.
BADRIDES
Well here's what I got to deal with yesterday, pothole patch decided it liked my tire better than the the hole they filled. So ended up having to get a new tire. Glad I got the road hazard, paid for itself in one claim.
Had this happen a couple of weeks ago to my son's 275-45-20. I used brake cleaner and prep sol to clean his up. Spray the tire down first with brake cleaner and watch the tar run off. I then let prep sol soak on there and picked it out with a screwdriver. His was on the front and shook so bad when he drove it, I had to do something. Got it all out and now rides smooth as silk. Took about an hour but better than buying a $150 tire.
OhFourChevy
Houston Tx
Well, yesterday, I bedlined my AR Bajas, they look good, I rednecked them, Today, I put in phillips crystal vision heads, highs, and fogs, today I'm redneckin some painted door covers(sanding them down, PTM) leaving the handle factory black plastic. PTM the chrome grille, leaving the plastic black, bedline Bowtie.
I've got plans to remove door ding guards, bedline the whole area under the split in the doors, fender flares, front and rear dechrome with bedliner, so more or less, two-tone white on bedliner, storm trooper status.
Id love to knock it out this weekend, but I'll save that for next weekend.
ScottyBoy
Shreveport, La
Oh, and I'm ordering the chrome center caps for them too
Paint the handle buckets but leave the handle black?
Hmm, at first I thought "WTF?" But then I thought for a second while looking at the picture of your truck. That actually would look pretty good on there since you are going with a black on white theme. Post some pics up when you get em painted.
OhFourChevy
Houston Tx
Will do, I'll post it tomorrow or monday, I haven't started painting, they're prepped for paint, but I've been busy smoking some ribs, and some cigars. I think it'll look pretty good, I'll try to knock it out early AM tomorrow
OhFourChevy
Houston Tx
Does anyone know if the textured black mirror caps on an LS can be removed, I'd think they come off a little easier. I don't want to cracking mine, is there a trick to it? Certain area to pry with a flat head screwdriver?
ScottyBoy
Shreveport, La
Yes, they can be removed, just be careful and work slow. A plastic pry bar/trim removal tool will work better than a screwdriver. If you don't have a plastic tool, then use a butter knife or similar thin metal tool. Start on one end and juts keep working your way around and as you move around the mirror, slide the knife or tool further and further between the mirror housing and the cap. Its held on with clips and with double sided tape, so by digging in there with a butter knife and working it back and forth, that cuts the double sided tape.
osiris94ej
Casper Wyoming
http://www.gmfullsize.com/index.php?threads/36860/
The mirror cap is held on with double sided tape and 4 clips where the arrows point to. Gently pry it off and the clips shouldn't break.
Sent from my SM-N920V using Tapatalk
Lol, just came out of the body shop and they put it on for me. Looks awesome! Wish I had the blue door handles too. Thx for the compliment!
wwiizz
