08HoeCD
Clayed and de-handled the rear hatch glass.
93blkongreenpro
Finished removing the molding and cleanup yesterday.
Looks good! Yall make me want to do mine. I want the 15 body moulding.
Got something in the mail today to hopefully be able to get the radio installed.
Clearly, I didnt read that I needed it when I purchased the Maestro Rr.
Edit:
The stuff.
I have to resolder the factory radio harness since the P.O. cut them off. The rest should be a snap. The Vehicle diagnostics plugs into the obd port, but I may solder the wires and hard wire it since I have my bully dog in there.
Now to print out the diagram for what goes where and what is not needed and get the Rr programed for thr truck and figure out my steering wheel secondary fuctions that I want to have.
Sent from my SM-N910P using Tapatalk
CHOO CHOO
BackPagePhil
Manheim, Pa
You people are bad. Now i pulled my moulding off too. I held out for soooo long and you shmucks finally made me cave.
Got drivers side done, will finish the passengers side tomorrow
vinnyray
Lancaster, PA
I held off for months but the damn molding was holding water and causing deposit buildup running down my door to the point where it started to rust
63Blackseries
Canada
I want to take my door moulings off too but do our doors ding easy? If some ****** person car door hit the sides?
CHOO CHOO
BackPagePhil
Manheim, Pa
Yes, why i left them on for 5 years. But after still getting dings, i said screw it. The moulding will only save you from so many. Carts and edges of doors still get to the door sometimes. I just found a new dent 2 days ago above the moulding.
93blkongreenpro
Scored a used weathertech rear cargo mat off ebay for $70. Then realized the husky rear mat new is only $90. Debating on whether to cut the 3rd row seat inserts out. But it macthes the front, soo, now to find the 2nd row, hopefully used, in black, for a decent price. Dont really want to spend $85 on it.
yukondoit
Stay Classy
Flagstaff, AZ
I need to get a set of those
Sent from my 831C using Tapatalk
93blkongreenpro
I put them to work today with fertilizer, grass seed, etc since AT&T decided to destroy my front yard to lay whatever new line they are putting down in my neighborhood. Why did they wait until the worse time of the grass growing season to do this. Plus, I change my son in the cargo area ( 1 years old) and he has marked his territory a few times.
CHOO CHOO
BackPagePhil
Manheim, Pa
Finished getting the passengers side moulding off and all the adhesive.
Still having trouble getting this residue off. Its like its oxidized, i dunno. Its just really tough and won't come off with any amount of goo gone or goof off.
Would a claybar take this off?
08HoeCD
Hit it with Meguiars Ultimate Compound. Easiest and most consistent application & results with a DA machine; doable and almost as consistent by hand.....but takes a lot more elbow grease.
wwiizz
