05Alive's 2005 Denali Resuscitation
Four down, like 16 more to go!
Bought a bulk pack of 194’s, I think I have 4 more places that take those, but it’s cold and wet and I really don’t want to be doing the bumper lights or plate lights right now. I’ll use the rest eventually.
Did the map lights and courtesy lights today.
Gotta order festoons for the dome lights, even though I read like 40 times they needed 42mm festoons I still thought they were 194s.
Looks dumb when the lights come on and the front is 6k and the rears are yellow.
ETA: Wow, that picture quality is horrible.
Colormatch colormatch colormatch...
05alive
05alive
Masshole
The lights? Yeah yeah yeah, I need to order more leds.
If you’re talking the truck, yes that’s the plan.
Going to fix the billet grille that’s loose and paint the grille surround. Either all black, or leave the chrome ring like on the obs that guy with the sbm denali did. Now it’s black and blue with a stripe.
05alive
05alive
Masshole
How did you do the courtesy lights in the door?
Popped them out with a flathead screw driver. I gently pried from the red side end, because the other end has tabs on it.
One it’s out, you kind of just wiggle and pull on the black plug, and the bulb and plug come out of the housing and you can remove the bulb from the connection.
I had to shave a little off the opening in the housing because my leds are kind big. There was a very fine lip that a razor blade shaved right off.
Then I just worked the bulbs in, connected the plug again, and reinserted them into the doors.
Yep I remember having to enlarge the opening on mine too.
adventurenali92
Big Bear Lake, ca
I had to do that with mine but now they’re loose.... they wiggle. Lol
05alive
05alive
Masshole
Uh oh.
My dad just got denied at what used to be "the place" for inspections because he has his fronts matched to the rears.
My friend also got denied there because he has fat cheater slicks on his truck that stick out like 1/4 inch on each side.
MA switched over to a new system with live cameras at inspection stations and it's scaring people off from letting anything even remotely questionable in. Stations won't inspect you if you roll the windows down and pull the fuse. (we tried that)
I was planning on going darker and getting shield tint this summer. Looks like a no-go for now. I think I have a new spot to go, but I will talk to the guy and see before I go in. I have until the end of August I think to find a spot.
One of my door LED's fell out because they're massive and don't clip in anymore, looks like I'll be borrowing mom's hot glue gun when I'm home next weekend. It's an easy fix but it's probably going to happen again so might as well fix it.
PG01
Up here to the right
Uh oh.
Welcome to NY
montanaboy65
