XLDenali06's Build Thread
05Single
afraid of the dark
Noice. Love my fleece chip.
Black grille looks great.
Shouldn't have any texture to the plastidip tho, should be just as smooth as paint. Did you use plastidip brand ?
I think sometimes if you go too thick on the coats and don't let it dry fully before applying the next coat, you'll get a textured look to it. That happened with my rims.
adventurenali92
Big Bear Lake, ca
Looking good!. How hard was it to swap fogs? Did you have to take the bumper off? The mounting bracket on my drivers side is broken and loose. So I need to order a new one but I've been putting it off because I don't know how hard the swap is.
XLDenali06
XLDenali06
Southeast Tennessee
I used the Plastidip brand, but probably did everything wrong that you can with the application. Lol. I've since watched some YouTube videos and am confident that my next try will go much better.
The fogs are super easy to swap. Just get up under the front end, unplug the harness plug from each light, and unscrew 3 bolts. Reverse the steps to install new ones ;-)
adventurenali92
Big Bear Lake, ca
Sweet deal! I gotta get mine done lol.
adventurenali92
Big Bear Lake, ca
Yeah, I have the 5S 8k lumens in my low beams. And they are fantastic. They have the little copper braided cooling tassels and they fit perfect in my housings. I went with their G8 12k lumen setup for my highbeams. While I love the output of the 12k and the tone of light and pattern, they have the little cooling fans behind them which makes fitment PITA. As far as a I found, Vouke doesn't make the bulbs for the highbeams with the braided cooling tassels, they only make them with cooling fans. But that's my only complaint. Otherwise I love them.
coffeeguy
