Z71 Step tubes
Stein2088
Butler, PA
I have an 03 Z71 I purchsed about 4 months ago and ever since I bought it there was/is a considerable amout of flex in the running boards when you step on them. I looked under them to see if a bracket was missing or something like that but everything appears to be in place and solid (no rust). My question is does anyone know if they are designed like this so they dont get bent up offroad or are my rocker pannels rusting out on me (I would be really shocked if this is the case. This is one clean hoe with only 70K) If anyone bought a Z71 new and can answer if it has always been like this it would be greatly appreciated... Thanks
Moved to the correct section :Handshake:
S
Stein2088
Butler, PA
I do not have this issue on my '05 Z71.
Thanks, I appreciate it... I mean they move less than an inch but still when you step on them it gets you second guessing... Thank for your reply though guess i'm screwed...
Donnie Yukonie
Yates Caretaker
No pun intended but how much do you weigh? if you are a heavier set guy they will flex a little , when I step on my rails they hardly move , but when my friend who weighs close to 270 steps on them they will flex
caminohill
Mine dont flex at all but I am only 180 soaking wet with wheel weights in my pockets
sent from on your sled
Danzigman
Galveston, TX
I weight 3 bills and mine do not flex. I step in my friend new f150 and they flex a little. My z71 rails are rock solid.
Z-56 Hoe
What do I do????
Houston
I don't think they should flex, check and make sure the bolts are all tight.
BPB
I'm 3 bills and mine flex like crazy I tried to stand on one to wash the windshield and I thought it was about to rip off
S
Stein2088
Butler, PA
I'm not Fat i'm Fluffy
I'm not what you would call thin but at 6'3" im a lil "Fluffy" at 210 but who knows how much the previous owner weighed and my gf weighs less than 130est (you never get a true weight HA) and they flex with her. All the bolts are tight and I've had a friend step on them and it looks like the flex is coming from the rocker but it's hard to tell with all the plastic on it.
Unfortunatly given the time of year and living in PA with no garage it makes it difficult to tear apart so ill have to wait for warmer weather. Since we are all on the subject has anyone ever sprayed theirs with bed liner??? If so what brand did you use and how well did it stick???
Gzes
the drifting 2dr
Wichita tx
yea the rocker usually will cause flex mine does a lil with the steps i put on but i rigged som wood in there and now it doesnt flex. tree branch cut into a small piecebis what i use lol
S
Stein2088
Butler, PA
Snapped Bolts
So finally had a warm/dry enough day to get under the hoe and check her out... I took a couple pictures to show everyone what I found... If yours are flexing I would take a look and see if you have any bolts missing. There are about ten on each side that were missing/sheared off. They are aluminum (SP?) so not exactly sure what I want to try and replace them with, but when you take the gray piece of plastic off they you will be able to see really quickly what I found and if you have the same issue
lefty
Mine is not a Z71, but a 2000 yukon xl, it flexes bad on the drivers side, thanks for the pic, I bet thats exactly the issue with mine!
JGARZA2213
Valparaiso, IN
Thanks for the pics! I know what I'm doing this weekend....
lefty
Well my mechanic said that all my bolts were intact. Not sure why it flexes so much, I guess I'll just have to deal with it..
S
Stein2088
Butler, PA
Not sure if your mech checked or not but the bolts that were missing on mine you had to take the Gray plastic piece off... All the bolts on the inner side of the vehicle are there and tight... Also anyone that has this issue what are you using to replace the junk bolts GM used??? And has anyone found a product to turn that ugly gray plastic back to black or is painting the best route
JGARZA2213
Valparaiso, IN
So I had a chance to take mine off today.....
I was planning on slapping some stainless steel bolts in there along with lock washers and nuts, but you can't get to the other side of it to be able to put the nuts on. It seems as though GM used an aluminum push pin type thing to secure these (no wonder they're loose). This is obviously a crappy design, but without being able to get to the back I think I may have to get a few of these from the dealer.
Any thoughts guys??
JGARZA2213
Valparaiso, IN
This is one of 5 brackets that bolt up to the truck to support the step tubes. As you can see ALL of them have they're bolts sheared off!
General Fodder
