Yukon Drop Prices
DoubleR
What is the going rate for a 2/3 drop install? I went to a local shop and they stated it would be $2200 for the kit, installation, and alignment.
How hard is the install for the Do it your self guy?
fiatdale
Houstons Best
Houston
Geez!! Ill do it for like $2k ;) Kidding. Thats insane. You can do it yourself if you have some tools, and then just get it aligned. Buy the kit from Tony - NorcalSS, I wouldnt think more than a couple hundred to install and an alignment for maybe $60? $2200 is insanity.
GalaxyBlackEsky
BlackedoutLT3
MD
Yes that is insane. Get the kit from Tony aka Norcalss and then you can do it yourself as I did but had help with a lift from a buddy or take it to a shop and have them do it for a few hundred and allignement should be more then 150. The rear is a very simple install and should only take 30-45 mins to do.
Mister H12
Undercover Racecar
West Tennessee
Aww I'd go vandalize that shop so bad! $2200 you could buy 10 2/3 kits!
Do it yourself, it'll take time if you don't have a lift, but its worth saving the huge costs people will charge. Unless you have a friend that works at a shop.
D
DoubleR
Thanks, I thought 2200 was crazy.
Mister H12 that was the first thing I thought about push a display over and say no thank you.
GalaxyBlack I see you are running 26' how is the 2/4 working. I plan to move up from 24' to 26'
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
ok few questions.
what size tires are you on now?
how soon are you going to go to 26s?
what year is your truck?
autoride or non autoride?
D
DoubleR
I have a 02 Yukon Xl, I am rolling 305/35/24 at the moment. I don't plan to move up to 26s until first of the year. I figure the rim upgrade would be last on the list. I going to say non autoride? Still debating should I stick with 24' or move up to 26' keep going back and forth with that....Thanks
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
305 35 24 can do a 3/5
295 25 26 3/5
295 30 26 2/3-4
Big Buttons
The SS Burb
South Texas
I had an '01 YXL with same size tires. Started off as 3/5 from Tony, ended up as a 4/6 no major rubbing.
Ihaveatahoetoo
