So last night I went into my garage and all I was doing was putting wire looms on my rcas and speaker wires to clean things up, I also moved my relay and wiring for charging my tablet from the drivers side to the passenger side. After I wired everything up, next thing I know only my front tweeters (which arent ran through the factory wiring) were playing!! WTF! I didn't change anything! All my speakers that are on the factory wiring aren't playing!The only thing I could think of that I did was when I moved the wiring for my usb tablet charger to the passenger side, I'm using a relay and I tapped into a harness plug under the passenger side cover for my accessory wire to trigger my relay, so I don't see how that could affect my speakers not playing, I even tried disconnecting that wiring and it still didn't work!
My system goes tablet > eq > PAC C2R-GM29 harness > amp > speakers....the pac harness connects to the factory harness so it uses the factory wiring to the speakers except for the front tweeters which I wired directly to the crossovers so that is the reason only they are playing.
Heres a pic of the harness I tapped into for my usb charger just in case this may have something to do with anything
---------- Post added at 12:31 PM ---------- Previous post was at 11:45 AM ----------
---------- Post added at 12:53 PM ---------- Previous post was at 12:31 PM ----------
damnit mods please move to 07+ section I didn't realize I was in 00-06
