Wire pulled out of neutral safety switch - how to put it back.
exp500
If I remember correctly, the terminal inserts from the front. Meaning if it pulled out the back, the terminal block and possibly terminal itself damaged. Easiest fix is mentioned above. Replave entire pigtail, crimp shrinkwrap connections.
S
silky28
Ok, so I found a replacement connector locally, which is super surprising because its Canada, for $37. So I will just replace the whole clip. Not going to solder it though because I do not feel like soldering a connect above my head while lying on the ground. I will grab some crimp butt connects and seal them with some heatshrink!
They make crimp connectors with heat shrink on them. Just crimp, then heat the connector with a heat gun and they seal around the wire. No need for separate heat shrink tubing.
89Suburban
Bull in the china shop
SE PA
Benito r
