Where O Where did my sensor go?
wma4553
I am stumped. Have a 99 tahoe with compass, temp mirror and the temp does not work properly. It is 100 degrees here but my mirror is warning me about icy conditions. I assumed the sensor was bad so I looked behind the grill for the sensor so I could make sure I would get the correct replacement, but could not find the sensor. I even removed the grill to make sure I was not overlooking it but no luck, I didn't even see a wire for a sensor to connect to. All the info I have found says it should be attached to the radiator center support. The only thing attached to mine is the horn. Any one have an idea where to look for this elusive sensor. Thanks in advance for your help.
W
wma4553
Thanks, You may be right, but would I get any reading at all if the sensor was cut out? It usually shows a ridicules reading like -30 and then it will switch to ICE. I thought maybe the PO had replaced the sensor and relocated it for some reason but I can't find it anywhere, I have looked all over the front of the truck and can't even find any wires so if it was cut out they must have cut it somewhere near the firewall so I will look again in that area.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
manual says nothing about "ice" in the display but a cut sensor would display oc for open circuit or sc for short. oc will happens when circuit is open or perceived temp is below -40°. with that it stands to reason they may be cut and touching each other in a high-resistance sort of way so to speak.go thru the harness that runs along the bottom of radiator support. that is where they originally were.
Yukon420SEL
PA/ Charleston SC
im going to say the wires are lose or brittle that go into the actual mirror, mine was doing the "ice" thing as well as telling me opposite temps all which turned out to be caused by a bad connection comming into the mirror itself
W
wma4553
Thanks guys, I will check the mirror connection and the harness tomorrow.
turk
Good thread... I had the same problem last year, but somehow corrected itself. Good to know how to fix the problem.
W
wma4553
You guys were right, I found the cut wires hidden inside the harness cover. I ordered a new sensor and now I have to find a 2 pin connector, maybe at a junk yard. Thanks again for your help.
chevyboy831
your local napa should have a harness "book" that looks more like a calendar with a lot of connectors for gm if you want to get a new one instead of a used one. just gotta make sure of what it looks like first. they may have it.
W
wma4553
Mirror temp is working, after I located the cut wires I got a new sensor from autozone and a pigtail connector from the junk yard, hooked it up, mounted it to the radiator center brace and it's working great. The connector is the same as the one used for the horn so there were lots of them in the junkyard. Thanks again for everyone's help.
W
wma4553
Found junk yard connector, installed new sensor, works great. Thanks all.
Hodmjstone
