What's Going On
mmeachem
So I come home in the driveway and go to lock it and nothing no locking not on the key fob or inside so I start it and it shutters alot
So what's going on
mmeachem
mmeachem
It did it this morning too but twice it turned over then shut off
But i got it started after
Rivieraracing
I'd be looking at battery as well considering the locking problem you have with the shuttering while idling!
mmeachem
mmeachem
I brought it over to the shop and waiting for a call
I don't think it's the battery
Maybe a short because my radio display and park drive display kinda blinks
mmeachem
mmeachem
They found nothing time to go to the chevy dealer
sparks
Tampa, FL
battery problem. i had a similar issue, wierd things were happening electrically. battery was 6 mos old. checked terminals etc etc etc finally got fed up and took it back, swapped batt, everytihing was perfect.
have it load tested, if it doesnt meet spec, look at new batt. also check main ground strap from battery to frame rail and from battery to engine block
be careful at the dealership, that could get extremely costly real fast with no real answer
mmeachem
mmeachem
Ok should I get the battery tested wait I might have a warranty with pepboys or bocsh batteries
mmeachem
mmeachem
Took it to pepboys and it turns out that the battery had a bad cell and the others were dry so I added some water drove it over and got a free battery
D Rollins
