what rims are better 26" or 24"
Status
Not open for further replies.
turboeclips
Austin, TX
26s!!! all the way.... if you get 24s, you will probably end up wanting bigger like me.
1sikyukon
SFV, CA
I got 24's....LOVE THEM...BUT...wish i would have got 26's!
26's all the way!
israel
Seal Beach, CA
6's all day!!!!!!!!!
Kon-Man
NAPA,CALIFORNIA
I'VE PRETTY MUCH HAD ALL SIZES AND STYLES.
IT ALL DEPENDS ON WHAT KIND OF RIDE YOU WANT, WEATHER OR NOT YOU ARE GONNA LOWER YOUR VEHICLE AND HOW MUCH YOUR WHEEL COST.
OBVIOUSLY THE BIGGER THE WHEEL, THE SMALLER THE TIRE. WHICH MEANS YOU ARE MOVING FARTHER AWAY FROM THE STOCK "RIDE" AND COMFORT.
NOW IF YOU SPEND $2500 ON 26'S YOU MIGHT NOT CARE WHAT HAPPENS TO YOUR WHEELS BUT ID PRETTY MAD IF I DENTED:emotions122: A SET OF $5000 BILLET 24 OR 26'S
I HAVE A SET OF 24'S WITH 295/35/24 TIRES LOWERED ON A 4/5 MCGAUGHYS DROP. WHICH GIVES ME MORE TIRE SIDE WALL (FOR A BETTER RIDE AND WHEEL PROTECTION) AND IT LOOKS PERFECT WITH MY OWERING KIT.
KEEP US POSTED ON WHAT YOU DECIDE.
israel
Seal Beach, CA
I love how people think a bigger sidewall directly affects the ride and rim protection. Oh my
NoChrome
Well typically, a tire with a tall sidewall will have more room to allow for deflection to adsorb bumps, the other big factor is the speed rating, the higer the rating the worse the ride. The only exception is run-flat tires. They ride rough no matter what.
israel
Seal Beach, CA
Im just sayin it's not the determining factor, yet people go by it like if it was bible.
Maximum Auto Works
i have to agree with israel.
And you cannot determine the ride of a tire based on the speed rating. A good balance on any set of tires will get a good ride. But if you are pairing up a pirelli with a low grade wheel you are going to have ride issues.
Another commonly over looked aspect is hub rings. If the wheel is not flush with the vehicles hub it will never be 100% centered on the rotor.
Just go with what you want on your vehicle. If you go with a 24 or 26" obviously it will not ride like "stock" but there are measures that you can take to not completely destroy your ride.
Kon-Man
NAPA,CALIFORNIA
Thats exactly the point i was trying to make!
There are many different factors of why a wheel will make your car/truck ride good or bad.
i was just stating the obvious,
MORE CUSHION = SOFTER RIDE.
MORE SIDEWALL = LESS CHANCE OF A FLAT SPOT ON ONE OF YOUR WHEELS.
"ISRAEL" LOL......
NoChrome
are you high?
have you ever heard of lug-centric? where the wheel rides on the lug nuts, instead of the hub? thats why lug nuts are cone shaped to center the wheel the studs instead of on the hub. If you think for a second having a wheel slightly off center of the hub is ok, your out of your mind.
BOSS
The People's A D M I N
Dallas
They make hub centric rings to accomodate people like me who didn't do their research properly before purchasing the wheel.
Lesson learned bro - find the hub size and make sure whomever you buy from sells you a wheel who's center bore (CB) matches the hub size of your vehicle. Otherwise you might find yourself replacing a bunch of wheel studs like I did.
BOSS
israel
Seal Beach, CA
are you high?
I dont care what most aftermarket wheel retailers tell u. No wheels are lug centric unless they are custom made.
Status
dizhai
