A SET OF $5000 BILLET 24 OR 26'Sisreal apparently hasn't owned very many different wheel and tire sets.
I love how people think a bigger sidewall directly affects the ride and rim protection. Oh my
Thats exactly the point i was trying to make!Well typically, a tire with a tall sidewall will have more room to allow for deflection to adsorb bumps, the other big factor is the speed rating, the higer the rating the worse the ride. The only exception is run-flat tires. They ride rough no matter what.
I think im going with 24'
i have to agree with israel.
And you cannot determine the ride of a tire based on the speed rating. A good balance on any set of tires will get a good ride. But if you are pairing up a pirelli with a low grade wheel you are going to have ride issues.
Another commonly over looked aspect is hub rings. If the wheel is not flush with the vehicles hub it will never be 100% centered on the rotor.
Just go with what you want on your vehicle. If you go with a 24 or 26" obviously it will not ride like "stock" but there are measures that you can take to not completely destroy your ride.
are you high?
have you ever heard of lug-centric? where the wheel rides on the lug nuts, instead of the hub? thats why lug nuts are cone shaped to center the wheel the studs instead of on the hub. If you think for a second having a wheel slightly off center of the hub is ok, your out of your mind.
