What causes high low pressure & low high pressure?
S
Stresst
you want the expansion of freon to happen just before entering the evap not 15 or so feet away from it. if the rear evap had it expansion valve all the way in front. the line between it and the rear evap would absorb all the outdoor heat and the rear evap would not work properly. When you put the it on the rear evap everything upstream is pressurized and hot. As soon as it goes thru the expansion valve pressure reduce freon get cold and the evap absorbs the surrounding heat. hence it gets cold and the blower blows air thru it to lower the temperature of the air.
Want a tech book recommendation just in case?
Tech book recommendation? Your post is my tech book recommendation! LOL Over the last few weeks my rear a/c was a little colder then my front. Now the front is cooler then the rear. This is definetely due to not having a rear expansion valve thats functioning properly. JMO
foreverfalcon40
3k on A/C **** that. Your damm ignorant. Guess you sit in alot of traffic in a suit and tie.
If you ever get to JP's lmk i live a few blocks away try and swing thru with the ESCAHOE!
S
Stresst
Ignorant huh....Don't tell me how you really feel! ;)
What would you do if you had no a/c in your daily driver? You would do the same effin thing. Dont get me wrong if I knew I was gonna spend half that I would have done something differantly but a bad hose turned out to be a nightmare. I really have to sit down and see what I really spent but imo it has to be between 2-3k. It sucks, chit it really suck but what can I do? I would have much rather built a stroker......
Batcomm1
