What are your stock fender heights?
99Yuk
Northern Ontario, Canada
As measured from the ground to the fender lip centered over each wheel?
Mine are 35" all the way around, on stock rims and tires.
I thought that the fronts are lower than the rears from factory giving a kinda raked look? Hence the term leveling, which is cranking the fronts to be level with the rears? How is it that mine are the same height? I have two new complete rear leaf spring packs, so I should not have any sag in the rear.
So what are your stock trucks measurements?
bub
jersey
they should have a rake to them. are you the original owner? if not, maybe the guy before you cranked up the front end to level.
TigerEyz3
Slow and Steady
TN
As previously stated, it could have been leveled by previous owner. Also, IIRC, the fenders aren't in the same location F/R anyway. I want to say that the depth of the front fender wells are deeper for turning clearance under compression (though it could just be an illusion).
99Yuk
99Yuk
Boy, I forgot about this thread. I was asking because I'm not fond of the front being the same height as the rear.
No, I'm not the original owner, so they may be cranked already, I'll have to take a look the next time it's up in the air. Thanks for suggesting that. I didn't clue in that a PO may have modded the truck.
If I pick 33" knobby tires for the summer, I'm was planning on cranking the fronts a little to clear, and a 3" block on the rear.
Think 80's here. You know, the Cheech and Chong van. Or better yet the A-team van. The original A-Team van. I know it's hard to do on a 4x4. But that's the look I may go with this summer.
I loved that A-Team van growing up. It was the cats ass and it looked so cool.
EastTXYukon
Longview, TX
Hey BowtieFreak, is that 35.5" on your suburban completely stock? Just curious because I had to crank on my t bars to get 35.5" on my 2 door.
The PO of my Yukon obviously didn't know much, because one of the t bar key bolts was backed off a whole lot, and the drivers side sat about an inch lower than the passenger side. I've got it nice and even now at 35 1/2".
If thats stock, I'm excited cause than means I can crank it up some more without getting too close to the stops.
bowtiefreak
No Quarter
Near Philly
Stock on little tires, no crank on the bars...I will double check that measurement later but I am pretty certain it is right because the tahoe is about 10" taller and it is a hair under 46" at the fenders
Ok, checked this morning: Front 35.5" front, 34.25" rear
TahoeJim
SE Ohio
Does anyone have an original OBS Tahoe brochure? I wonder if it had a diagram of the truck showing various measurements...wheelbase, bumper height, ground clearance at rocker panels, etc. You could easily extrapolate what fender height was when the trucks were new and there wasn't 10+ years of usage causing the leaf springs to sag, torsion bars to lose some tension, etc.
My 99 with 80k miles when I bought it last year was sitting fairly low. After getting the rear leafs rebuilt and adjusting the front end to match I think I'm pretty close to how the truck would have been stock.
265/70-17's mounted up, I have my truck set at 36.5". The stock tires on my truck were 245/75-16's and those have an overall height difference of 1.2" (30.5" vs 31.7"), divide that by 2 and my truck with stock tires would be sitting at 35.9".
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
I dunno. But what ever it is it ain't high enough. As evidenced by the curled and beat steel from the 35's rubbing.
99Yuk
99Yuk
So yesterday the truck was in getting it's oil change and lube job, so while it was in the air, I took a few pics.
Driver's side:
Passenger's side:
From what I can figure so far based on your all feedback is that a 35" height seems to be a stock height for these trucks. If that is correct, and by looking at my passenger's side index bolt. There is not enough thread left on that to crank it of any value. So I can figure that after 11yrs of running the roads that the bar is plumb worn out. So now I figure that I can buy a JY bar, but probably deal with the same issues. So that's out.
I think that if I want any kind of small lift for the front, that I'm into buying new keys for it.
What do you all think?
Drewphil
