Weird Coolant Issue
tomloans
I have a 2003 Tahoe LT. When vehicle is at operating temp and after some driving, the fluid level will drop to a point where my "low Coolant Level" light comes on. Then when I turn off the engine, the level comes slowly right back to the normal middle again. Do I have leak? Anyone have this happen on theirs?
alaska_guy
Alaska
I just bought a burb and it also had a leak as well. It's at the mechanics so not sure as I didn't take the time to check myself as he owes me some shop time... However, main cause of coolant loss on these rigs are the following.
throttle body coolant hose leaks
overflow cap not sealing and basically evaporating the water out ($7 for a new cap)
water pump gasket are leaking
old hoses leaking by engine area and or by frame rails if you have rear heat option
oil cooler leaking
Castech head failure (cracked head by oil galley in head)
Head gasket failure.
Good luck!
Seems to me the system is open and not building pressure. You can rent or borrow a pressure test kit at the auto parts store to find out.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Yep, pressure test and look high and low for any possible coolant loss. Have you done any engine work to it lately? Since you say the coolant level seems to always come back to the SAME SPOT after it cools down I am gonna guess that you likely don't have a leak. I would also check the plumbing between the tank and the radiator for free flow. I am also assuming your temp gauge stays normal.
T
tomloans
Thanks guys. I just bought a pressure tester as my other car is losing coolant (slowly) and I cant locate the leak either. I will put it on the tahoe and see if anything is produced on the ground. Of course the greatest fear is head gasket or worse cracked head. The car is not overheating and running perfectly. No smoke whatsoever.
T
tomloans
just did the pressure test and immediately it started dripping. I was surprised because while it ran, it leaked so slow I couldn't see the source. But at 15 PSI and cold it started dripping right away. This has been going on for about 3 months.
The leak is coming from the thermostat gasket. Easy fix. So if you have my symptoms look there first. Very slow loss of coolant - unable to locate leak. The pressure tank sinks to 1/4 (low coolant light will come on and off ) then back up to half when you put it in park and with a gradual loss of coolant over weeks.
Good you found it, I was under the impression it wasn't leaking and probably just had trapped air.
OR VietVet
Willamette Valley
"So if you have my symptoms look there first. Very slow loss of coolant - unable to locate leak. The pressure tank sinks to 1/4 (low coolant light will come on and off ) then back up to half when you put it in park and with a gradual loss of coolant over weeks."
In the OP you never said anything about loss of coolant or having to add coolant. I am glad you found it though.
I guess when I read these posts I am going to have to start assuming some things.
ks03
Fool Excess Member
Im saying this because of the of large number of water pumps leaking, and the small number of thermostat gaskets I’ve seen leaking. Take a hard look at your water pump, and make sure it’s not coolant running down to the thermostat from the water pump.
kind of doesn't make sense if the coolant level is normal when it's not running, a tiny leak wont cause the level to drop like that while it's running, normally a small leak is just that a small leak and you LOOSE coolant and the level goes down from normal and stays that way.
OR VietVet
Willamette Valley
My thoughts too. I would not be surprised if fix the leak and still has a problem/concern.
ks03
Fool Excess Member
My guess is that the conditions were poorly described. I’m thinking when you are borderline low enough to trip the low coolant sensor, the lowest the coolant will be at the sensor is when you start a cold vehicle, and sustain higher rpm.
OR VietVet
Willamette Valley
When I ran shops the most important part to start the repair was info from the owner. I asked a bunch of questions and did my very best to duplicate the problem. Sometimes here, the people asking for help are not the best at describing the problems and when they occur. Most of us here start out asking them questions because so much info is left out. So many times I see a section of the forum for each rig but during the problem description process, we don't get the exact year, model or engine/trans description.
T
tomloans
Sorry guys. Yes I have had to add coolant intermittently. I should have noted this for sure.
I bought a pressure tester for the cooling system for my e38 740I.
It was a good thing I did as it came in very handy for the Tahoe. I put it up to about 15 PSI and it immediately started coming from the seam (not the lower radiator hose but the seam of the thermostat housing) I changed the water pump at about 180K along with the thermostat ( I have almost 200K on the vehicle ). It looks like something didn't set well when I put on the thermostat. I am going to give it about a month and see if the problem is solved.
It is kind of odd that I couldn't see this while the vehicle was running or as it cooled down. You would think i would have a small puddle under the car. Strange that it took a tool to provide the location of this leak and profusely. It was leaking pretty good too at 15 PSI. Well we will see if this was the only leak I had. Give it some time. I saved the coolant and ran it through a sieve. It seems to be running fine and not losing any coolant so far but again it was a slow leak over time.
Let me know if I missed something. These forums are super important to keep my vehicles running. I want to keep this car well past 300K miles. I think it can make it.
incidentally , the e38 did not show the leak like the Tahoe so I am still confused as to where the slow leak is on the 740i. I replaced the entire cooling system and seals/gaskets methodically. Maybe it is air in the system. Anyways thank you for your help.
T
tomloans
Just did the pressure test again while cold after running it about 20 miles yesterday. Holding pressure. This is rare to have this thermostat oring leaking but here it is. If something else comes up, I will let you guys know. Here is one of the best $45 I spent...
WINTOOLS 18pcs Auto Cooling System Radiator Cap Pressure Tester Kit Pump Gauge Adapters https://www.amazon.com/dp/B07JZ7STBG/ref=cm_sw_r_cp_apa_i_H3z0Db7RRN845
BlacktopBandit76
