Want to make a 6.2 stupid fast
MUDHOE
I plan on buying a 6.2 1/2 truck. I want to throw a supercharger on it and i want to keep the 6.2 motor and just make it stupid fast, i know turbos make more power but i wanna stick with a supercharger. Also my buddy says we need to run it on e 85. Suggestions please
AZSCTACO
Phoenix, AZ
Vortech and Edelbrock are some options.....
Got about 8-10K laying around???? :cheers:
M
MUDHOE
Money isn't laying around but I can't take it with me when I die. I was told you could get the most power out of a Whipple and my buddy says you'll make more power on e85. I'm just looking for more input on it.
M
MUDHOE
so bigger fuel lines and new pump and what?
M
MUDHOE
Here in good ole Nebraska we only get 91 and its a rarity to see 93
ezdaar
Chat Troll
Redneck central, Aka Houston
I LOVE E85 for forced induction setups! Can run WAY more timing and boost before knock.
Lets face it, if your going for boost and running E85, the MPG doesn't matter.
Just be warned one of the best properties of E85 and up is its Cleaning properties.
It will clean out any corrosion it touches. side effect, clogged filters and injectors until its squeaky clean inside that fuel system.
Rule of thumb is to up size injectors and fuel flow by 30% run PURE E85.
M
MUDHOE
What kind of mileage would I get with a setup like that ^
Big Buttons
The SS Burb
South Texas
When I was running E-85 for a while its a noticible difference in power but a huge drop in mpgs. My burb is a flex so wanted to try it out. I have friends running E-85 and boost and they love it.
tights24
Probably somewhere around 8.1 gallons per mile..... hehehehehehe
JennaBear
Resident Ninja
San Diego, CA
You cannot safely run E85 with a supercharger on a new GM flex fuel vehicle. This is due to the method in which GM calculates/estimates ethanol content. Since 2006, there has not been an alcohol sensor in the vehicle, instead the ECM relies on a calculated approach that compares pre-fill readings to post-fill readings. That calculation requires the engine to be run in closed loop for the first 10-15 miles after fill up (with few exceptions), which is dangerous for a vehicle which needs significantly more fuel when in boost.
The fuel injectors are too small for boost and E85 and the fuel pump is going to be tasked at high RPM as well.
If you install an alcohol sensor to discreetly determine ethanol content, then there won't be any problems. We have one sitting on the shelf waiting to go in my Denali along with Injector Dynamics ID1000s.
Fast55
Ventura County USA
I'd listen to Jenna on this. I don't run E85 and won't based on issues friends have had with fuel system problems, finding fuel, etc. It does make more power, but can be a PITA with forced induction and the truck will gobble it up like a starving kid in a candy store. Better to build/tune for max cojones on 91/93 pump gas. Just my .02.
NORCAL SS
SUV SUSPENSION GURU
Ill be finishing up spray on mine on a 100 shot should be running 12.60s
now easy combo
whipple 2.9
meth
yank 3000 stal
373 gears
10 psi
cam and wcch heads
Will do 700 rwhp easy
My old trailblazer ss ran high 11s on a 50 shot with minor bolt ons. The yank converter woke it up major!!!
JennaBear
Resident Ninja
San Diego, CA
That on your cts? 700 is more than double factory for the esky.
Sent from an ice cream sammich.
NORCAL SS
SUV SUSPENSION GURU
Yes on esky. Buddy did it here.
2.9 maro on esky changed drive setup
Lt1z cam
Wcch heads
Meth
1 7/8 long tubes
12 psi
Was like 743\702 at wheels
JennaBear
Resident Ninja
San Diego, CA
Ah, that cam pushes the power band higher, he probably peaked at 6200rpm. So what is the 2.9 maro?
NORCAL SS
SUV SUSPENSION GURU
2.9 whipple from camaro. Hes trying to figure out how to do the 4.0 whipple without having to hack up the wall
M
MUDHOE
So jenna even if you changed injectors and changed to fuel pump which we had planned you would still have problems? how do you go about adding the alcohol sensor?
Bwaldron
