Vibration on acceleration
Segalldontfly
2021 Denali. Hearing a slight vibration (almost like a cellphone buzzing) when accelerating. Mostly happens on right turns. Sounds like electronics or plastic pieces touching and vibrating. Any ideas?
Micahsd
That’s a tough one.
Only thing I can think of is if you have the air ride suspension maybe that’s doing something or making an adjustment due to the body role of turning right, but I’d think you’d hear the same thing turning left. I don’t have the air ride suspension so not sure if it makes a noise a person would hear.
S
Segalldontfly
Thank you and sorry for the vague description. The noise is only for a second or two and then nothing and is not consistent.
Tire pressure is fine and I have stock 22s.
Going to check the engine bay to see if there are any loose wires, etc. it sounds like light plastics bouncing against each other.
Will also try to upload a video.
No air ride in my ride …
Drewphil
