Very pleased w/Amsoil rear diff fluid
HankHill
Just passing along my experience & results. I just serviced the rear diff on my new-to-me 2000 'Hoe. I don't believe the fluid had ever been changed in the 158K miles on the odometer. The rear end was clunky stopping & launching.
Change the cover, gasket, and filled with Amsoil synthetic 75W-90. Smooth as silk now. Very pleased so far!
dsltrc
Virginia Beach, VA
Nice... how much did u use, what was the cost and where did u get it? I probably need to do both front and back as well as the tranny...
H
HankHill
The rear diff was about 2.5 quarts, so I bought 3 at around $12/quart. A few mom$pop shops around me deal the stuff. And the gasket & cover kit was around $50 at the dealer...
msark
Why doesn't in need the ltd slip additive? 3 days ago I changed mine and went with the additive and Lucas gear oil... Wish I had seen this first!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Possibly because it does not use the mechanism type that require it.
---------- Post added at 05:58 PM ---------- Previous post was at 05:58 PM ----------
What told you to use the modifier to began with?
Freedom Motorsports
I have run Amsoil in everything I own for years. They don't recommend adding other slip lock additives with their lube unless it is their slip lock additive because it is formulated to compliment the additive package already in the gear lube. I personally have never run the slip lock additive in mine but have used the 75w-90 in many 1/2 and 3/4 ton trucks and never had issues. When changed it has always "looked" as good when it came out as when it went in. I haven't changed it in the Yukon yet but I am in the process of converting everything over now.
Hotrdd
Same fluid in the front diff. Or is it something different?
Brian12019
