Upper a arms on lowered TAHOE!!
Byoung1330
Cookeville tn
I was going to lower my Tahoe some more in the front and before I ran into alignment issues I wanted to change my upper arms since they are in need of changing. Does anyone know if the Moog CK80826 arms with the offset bushings are the same as installing the 4955 belltech bushings? If so it would be easier an cheaper to just buy the moog arms with new ball joints and offset bushings already installed.
The Moogs give 2 degrees of positive camber, same as the Belltech bushings. It is recommended to use the press tools to install the Belltech bushings, so you may wanna factor that into the price of getting the BT bushings and having them pressed in (assuming you don't have a press and have to outsource this labor). Plus, you may wanna get a second set of arms to be made up so you can just swap them in to reduce downtime. Then there's the ball joint aspect- the Moogs come with a new one.
The $150 for the pair of Moog arms seems to be the best deal when you factor getting new ball joints and offset bushings already installed and you can just swap 'em in with minimal downtime.
Byoung1330
Byoung1330
Cookeville tn
That's exactly what I was going to do is get the moogs if the offset bushings were for lowered vehicles I cannot get the seller to tell me if they was for lifted or lowered vehicles They are only 75 a piece on amazon. It's way better to go that route then get the belltech bushings and press them and all that hassle if these are the same as them. I just couldn't get it verified.
According to Moog themselves and Moog retailers such as Summit, they give 2 degrees of positive camber, which compensates for the negative camber lowering causes. Yes, that $150 price I got was for two of them at $75 each from Amazon.
I suggest you mark the alignment eccentrics where the stud is so you can put everything back how you took it off to minimize the change in alignment. This should keep it close enough to safely drive to an alignment shop, assuming your alignment is good now.
Byoung1330
Byoung1330
Cookeville tn
Yes I know all the information I'm being told. I installed everything on my Tahoe in a driveway with no lift. lower control arms spindles you name it I just wanted to kno the difference in the beltech 4955 bushings an the offset bushings in the moog arms. If it was the same an if it was its pointless to add the beltech bushings to the arms when u can buy a new arm with ball joint for bout the same price. But I appreciate all the replies
Byoung1330
Byoung1330
Cookeville tn
They just did not specify if it was for positive camber but iamdub and another member said it was so that was the info I was trying to figure out thanks
Byoung1330
Byoung1330
Cookeville tn
And the rk moogs are the economy version. Has anyone had any luck with these? I dont want to cheap out on ball joints as it holds my wheel on lol. An I kno the upper arm does not really take alot of stress like the lower it's just a follower. So maybe the rk is ok for the upper?
...Has anyone had any luck with these??
You rely on your "luck" for slot machines, not suspensions or brakes.
...I dont want to cheap out on ball joints as it holds my wheel on lol. An I kno the upper arm does not really take alot of stress like the lower it's just a follower. So maybe the rk is ok for the upper?
I'd strongly advise against cheaping out with the ball joints, as you would be with the RK series. They may be "okay", but for how long and up to what amount of stress? You don't wanna have such questions in the back of your mind every time you're approaching a rough patch on the road. I've had an economy ball joint break and the few dollars initially saved was FAR lost in repairing the damage. It was a few weeks old and snapped as I went over a considerably mild railroad track that I crossed every day to and from work. Even if the cheap part doesn't break, just having the peace of mind is worth the extra few bucks.
I ended up buying the ac delco professional series they had better reviews than the moog
So you're gonna get the Belltech bushings installed in those arms?
I recently replaced all of my suspension when I lowered it and went with ACDelco Professional since I scored a hell of a deal on the arms. After comparing and tracing the numbers, letters and symbols on the box labels and stamped on the arms themselves, I found that they were Moog arms. Members of this forum or it may have been another GM truck/SUV forum reported the same findings with the ball joints themselves and with the arm assemblies. ACDelco Original is the line of parts from the factory and dealerships. Although, this may not directly apply to the GMT800 parts.
Byoung1330
Byoung1330
Cookeville tn
No I do not think I will need the offset bushings It aligned fine before so I just went back with stock arms. I thought I may go lower but I'm pretty low I think I'm just gonna lower the back a little more. Yes I got both uppers for 120.
jasonc
if you get a bushing DO NOT by Moog there junk by ac delco you will thank me later
johnsonwillie199
