Transmission to transfer case seal
smoky02
I have to drop my transfer case and replace the seal between the tranny output shaft and the input to the transfer case. Does anyone know or have a step by step DIY for this? I have a 97 2 dr Tahoe 4x4. Also if anyone has anything pictures that would be awesome also.
Thanks in advance,
Brandon
SunlitComet
OBS Jedi-Do Good
unknown at this time.
REMOVE OR DISCONNECT
  1. Negative battery cable.
    • Raise and support the vehicle.
  1. Transfer case shield.
    • Drain the oil from the transfer case.
  1. Front propeller shaft.
  2. Rear propeller shaft.
  3. Vent hose from the transfer case.
  4. Electrical connectors and wiring harness from the transfer case.
  5. Transfer case shift linkage at the transfer case.
    • Support the transfer case with a jack.
  1. Bolts securing the transfer case to the transmission adapter.
  2. Gasket
    • Discard the gasket.
INSTALL OR CONNECT
  1. New gasket to the transmission adapter.
    • Use gasket sealer to hold the gasket in place.
  1. Transfer case to the transmission adapter.
  2. Bolts securing the transfer case to the transmission adapter.
    • Tighten:
    • Bolts securing the transfer case to the transmission adapter to 45 Nm (33 ft. lbs.) .
    • Remove the jack from the transfer case.
  1. Transfer case shift linkage at the transfer case.
  2. Electrical connectors and wiring harness to the transfer case with new straps.
  3. Vent hose to the transfer case.
  4. Rear propeller shaft.
  5. Front propeller shaft.
  6. Transfer case shield.
    • Check the transfer case lubricant level and add oil if necessary.
    • Lower the vehicle.
S
smoky02
Thank you sir, but I'm actually looking for the seal from the rear of the tranny to the transfer case...not the adapter seal.
SunlitComet
OBS Jedi-Do Good
That is what you got to do to get to it.
The instructions above are to remove the t-case to get to the seal.
The picture below illustrates the t-case input seal on the t-case is that the one you want is is it and the tail of tranny?
S
smoky02
Oh ok, thank you...I will be starting on this in the morning...hopefully it all goes well.
Buford bubba
