Transmission Fluid Change Denali XL
Costal_Cat
Hi all,
A little background
2012 Yukon Denali XL about 130 k and some change.
Lots of highway driving and towing of my travel trailer and boat
When I got the Truck with around 80,000-mile Transmission Fluid looked pretty good, which I was ok with as I would rather it look decent than cherry red as if someone just changed it.
Drove it that way for about 25,000 miles no issues, Tranny temp on a super hot South East day on I95 might have gotten to 210 at its worst. When we evacuated from NC during Florance it was a little crazy in that I was out of town on business flew in and turned around the kids, dogs, truck, trailer, and the second car in about 4 hours and hit the road. Needless to say, I was not as detailed oriented as usual when loading the trailer and truck and it probably had a little more weight than usual and probably not distributed as well as it usually is. That night I noticed both the tranny and water temp were higher than usual not crazy high just out of its normal range. We stopped to camp for the night I checked both cooling, and tranny fluid and both needed a little, so I topped them off. The next day was a nightmare of a drive on i95 south what usually took 2.5 hours to get through SC took 5, and it was hot weather wise. Once in Georgia, I transferred one of the kids and dogs to the wife's car and told them to meet me in Orlando because of the temps I planned to ride with no AC on the windows down because it seemed like that kept the temps in a more normal area. Once we got put in Florida, I got a shop that had excellent reviews to check out the truck. He said thermostat was good and the tranny fluid did not look bad, but he would recommend to just change the filter and add back what is required when doing a change, which is what I would do. He did note that the fluid was darker than he expected, but the magnet was fine when he did change it so just keep an eye on things. After that, it drove a lot better temps were back to normal, and I have probably put 6-7,000 miles on it since towing and such with no issues
After this last trip, it was during that little Feb heat wave and the temps were climbing a little higher than normal, hit 212 -215 once and the fluid is looking a little worse for the wear but not burnt by any means.
So now the question, I was going to do a complete fluid change today in the driveway. Pull the transmission line at the radiator dump about 6-7 quarts out using that method.. . Note I have no transmission issues, but I tow a lot, and I know that if the fluid is not changed, it will certainly get to be an issue. I have read a million opinions of the good and bad of changing out fluid, so I was not going to run it through until I see a good red color I was merely going to pull some out and replace.
Any thoughts on this? Should I run a complete change? I have three gallons of fluid sitting here in the garage and could do so or should I just dump 4-6 quarts and replace?
TIA
thompsoj22
Since the pan and filter have been R&R and no signs of debris were evident i would advise a full flush with the twelve quarts you currently have, With the benefit of not having to drop the pan! Understand you tow heavy and alot, Your trans is going to fail so start preparing for it financially and go with a quality "remanufactured" designed to tow, The trans is quite likely talking to you with higher temps from slippage/friction. Changing the fluid is allways risky on high mileage/wearing auto transmissions but based upon your description of the vehicle i would do it.
Costal_Cat
Costal_Cat
Thanks, guys this is my mindset as well.
Any suggestion on the new transmission a quick google shows a ton of places but anyone have a vendor recommendation? What should I look at with regards to upgrades for better towing?
Chrismnj
NJ
I have used circle d transmissions
PG01
Up here to the right
I think you made your mind up already but 1 more opinion for ya because ya know.....Full flush and filter imo. If it goes it goes. Id rather have peace of mind knowing its fresh fluid and filter and since its been done before I actually think you may be ok.....ish. Its not like you went to 130k on same fluid and filter andvthen serviced. Thats when, imo, you get most of your problems developing. Meh my 2 cents anyway..
intheburbs
SE MI
What am I missing here? The trans hit 210-215 a few times and we're already talking about impending failure?
Everybody does know that the "trans hot, idle engine" warning comes on at 265°, right?
And everyone knows Dex6 can go even higher than that for short periods with minimal degradation, right?
I've had my transmission much higher than 215°, it has 190k miles on it, and it still functions/shifts perfectly. I drive it hard, tow really heavy stuff, and generally abuse the hell out of it. Moving 16,000 lbs up towards the Eisenhower Tunnel:
To the OP - your transmission is not on the verge of failure. Do a full flush and keep on trucking. I do a full flush every 50k. YMMV.
Costal_Cat
Costal_Cat
Well damn, that was easy! Looks good was quick to do... @Galante I just ordered a filter an gasket. Given that was that quick I'll do that here once it comes in... Thanks everyone
Chrismnj
NJ
do you have transmission cooler?
Costal_Cat
Costal_Cat
Yep, 1500 Denali XL I have the stock cooler but may change that out for a bigger one... But with that said it is good to know some of the temps' people hit and are fine... My local shop said he doesn't worry about his tran temp until it is running at 240... I really love this truck so I'm just looking to do as much preventive maintenance as I can on my own to save some cash... I'm going to do the transfer case and axle grease next weekend and keep trucking, thanks for all the quick advice today.... Flush done, washed the truck and now I'm cracking a cold High Life and enjoying the rest of the day!
Cheers!
Chrismnj
NJ
these temps are ok but not for long run anything above 200 is slowly damaging transmission.
Costal_Cat
Costal_Cat
Thanks @Chrismnj
I'm pulling the trailer down to FL at the end of the month when I'm back from my work trip so that will give me a good read on how's it is going....
I will say that was some nasty look fluid and looks way better now at the dip-stick, that alone has gotta help at this point....
intheburbs
SE MI
Only thing is its not a 2500 its 2012 yuk denali xl.... 1500 last i checked
Chris quoted me, and asked, "Do you have a transmission cooler?" at the top of this page. Last I checked, I think it's safe to assume he was asking me, not the OP.
Really? Normal operating temperature for the 6L80/90 is 190-200°. So running at 201° is slowly damaging the transmission? Dex6 was a pretty large leap in the temperature capabilities of transmission fluid. You should really do some research before making comments like that.
If you really want to be technical, running the transmission at all is slowly damaging it. The question is, at what elevated temperature do you see significant reduction in life of the transmission? I'll give you a hint, it's higher than 215°.
Chrismnj
NJ
Really 201°? I always try to keep mine Under 200,
thompsoj22
Geeze, I didnt mean to get you on the defensive! My opinion to anyone is if they tow heavy and frequently the trans is wearing at an accellerated rate and be prepared for a trans replacement and purchase one designed to tow. Temps increase in auto's from slippage/friction not from "lockup", he noted temps "out of the norm" for his vehicle, I didnt mean to imply imminent failure. Now based upon your pic's, temps, RPM i think you should be carrying a broom and wheelbarrow/kittylitter to assist the towtruck with cleaning up your mess. I dont think you should be proud of having to run that thing like that, more lucky that it hasnt grenaded yet? Oh and i allmost forgot, If you ever decide to sell your vehicle dont forget to to word the for sale sign as "generally abused the hell out of it"
:popcorn:
curbud
