Transfer case fluid?
pwtr02ss
Tennessee
Ive seen people use synthetic, not sure it hurts anything, I just went off the what it came with front he factory.
NGAneer
NWGA
I guess it's true that GM switched to Dexron VI for the later transfer cases. Mine for sure says auto trak II. Go with the manual. At least ATF is easier to find.and cheaper.
Just purchased a rig like yours, same year and style and mileage. Going to start the 100k service tomorrow. Mine calls for Dexron VI for the 2 speed transfer case, MP3024.
F
farhanm
Oklahoma City
Very nice. I plan to start in the morning as well. Make the most of the long weekend.
I was looking for torque specs for 2009 yukon CL if any for the following. Items
Front diff drain plug
Front diff fill plug
Transfer case drain plug
Transfer case fill plug.
Thanks
Farhan
Rear differential fill plug
Rear differential housing bolts
NGAneer
NWGA
F
farhanm
Oklahoma City
Thanks Matt, i had gone through that particular thread but wasnt sure if some of the numbers there apply to my truck. based on details on the Wiki page my Truck comes under GMT930 category.
Ill see if the dealer service dept can give me those.
thanks
Farhan
NGAneer
NWGA
thanks
Farhan
I just use the GMT900 specs. Same general equipment for all 1500 models.
Thanks
Farhan
Front Differential Drain and Fill Plugs - 24 Foot Pounds
Transfer Case Drain and Fill Plugs - 13 Foot Pounds
Rear Differential Fill Plug - 24 Foot Pounds
Rear Differential Cover Bolts - 29 Foot Pounds
This information comes from my ALLDATA DIY subscription.
08grey
Why not just use dealer fluid? Its been good so far.
Sent from my SM-G950U using Tapatalk
F
farhanm
Oklahoma City
finally got done with the fluid change. it went surprisingly easier than i thought it would be. during the rear diff fluid replacement, i also took the spare down and cleaned/lubed the winch assembly.
so far everyting looks good. no leaks yet.
Thanks
Farhan
Rosson03
Kentucky
I did quit a bit of research many said it is a good,high quality oil. I also replaced my front and rear diff with royal purple MAX Gear oil 75W-90.
Looking to do the same..... Any regrets
Synthetic dex 6 for engine and what about syn dex 6 transmission?
buck91
Well the manual also says Dexron VI. But I have the selectable dial selector.
So that's what's confusing me.
Here's what's the manual says and a picture of the switch.
Again, I may have misunderstood, but Auto trak II was for the this type of selectable switch and Dexron vi was for AWD with no switch.
Thanks
Farhan
Looks exactly like my 2011. Manual wasn't very helpful and I became worried about it after reading some posts here for Autotrak II since I just changed with Valvoline MaxLife ATF. Well, just spoke with the local dealer who says they are calling for Dex VI.
Rosson03
Kentucky
So let me see if I got this right
75 W - 90 front and rear
Synthetic dex 6 transfer case
Dex 6 for transmission
Going synthetic blend in the engine
M3kanic
Depends if you are awd or 4wd
M3kanic
Also 75w 140 for lsd or you need to add lsd fluid to it for the rear. Most of us just use 15w 140 regular for the front.
M3kanic
If you are 4wd you use auto-trac II but if your awd takes dex VI . Unless something has changed since the last time did the research for it.
Phlipnstik
