Trailblazer Problem,Need Help!
Porkins
Dead Terrorist
Atlanta,GA
I've been searching Google but haven't found an answer. The driver side door window and lock controls stopped working over night. They just worked fine at 8pm yesterday. All the other windows and lock controls work fine. I checked the fuses they work fine. I popped up control panel made sure everything was plugged in and nothing. I'm hoping someone knows how to fix it?
Thanks
-Joey
Porkins
Porkins
Dead Terrorist
Atlanta,GA
Not yet, I got busy with family yesterday. I will remove it later today if the weather permits.
07Denali
Did you get this fixt or not? If not try switching around the switches and see if it works. If so you have a bad switch, if not, start checking power to the switch and to the motor etc.
badtothe bone
western pennsylvania
It was probably just that the door window regulator quit working.
Some models the window will go down and will not go back up - while other models the window goes up and then will not roll down.
Surburban's are known for going down and not going back up.
Avalanches are known for going up and then not rolling back down.
rddixon
