Towing Mirror Installation
01Konvict
Boats n Hoes
Raleigh/SML
pop the triangle piece off in the corner of the door then unbolt the old mirrors and disconnect the wires at the plug connection then install new ones
C
Cole123456
Seems easy enough... sounds like a good idea, so i can see around my stinking travel trailer.
Thanks.
THE YETI
Director of Operations
South FL
We had to remove our door panel to do ours. The harness is under the window switch. Unplug from there and then the wires themselves are held in by plastic clips down through the door.
juggjiggler69
Hope the mirrors u got have long enough bolts cause i had one hell of a problem getting mine on due to the bolts and the anti vibration brackets they gave me barely enough thread to start the nuts but i managed and they look and work good
Sent from my SCH-I535 using Xparent Blue Tapatalk 2
TacHoe
DC
^^Gary you order from the same vendor by chance?
WildBill
I dont know if you have heated mirrors stock, but they make the Towing mirrors like that with heat in them for just a bit more $$$. They are on my wish list.
C
Cole123456
Yes, i have heated mirrors
http://www.amazon.com/Fit-System-62...cement/dp/B005H12QXG/ref=cm_cr_pr_product_top
if you read the description it supports the heated function (or am i missing something?) :
2003 to 2007 CHEVY Avalanche (03-06), Silverado Full Size Pick-Up (03-06), Silverado Classic Full Size Pick-Up (07), Suburban (03-06), Tahoe (03-06), GMC Sierra Full Size Pick-Up (03-06), Sierra Classic Full Size Pick-Up (07), Yukon (03-06), driver and passenger side mirror set, heated glass and power adjustable, foldaway function, textured black finish, with a dual glass. Driver and passenger side mirrors are included in the set. Heated and power adjustable, OE-comparable wiring harness (no "pigtail" connector) for hassle-free installation. Can fold mirror to park in narrow garages. Black grained textured finish. Mirror is equipped with an additional blind spot mirror.1. Power, heating and turn signal functions will only work w/vehicles that originally came with these features. 2. Mirror has power adjusting glass, but does have power extendable or power foldaway features. 3. If vehicle is equipped with curb assist this feature must be turned off from the DIC (driver information center). The DIC is accessed by pressing the “i” button on the steering wheel. Scroll the menu to “Curb View” setting and set them to OFF. This will keep mirrors from moving out of adjustment. 4. 2007 models must be Silverado/Sierra Classic Extendable towing mirror, with turn signal, dual glass top (flat), bottom (convex).
C
Cole123456
installed.. picture attached.
was pretty easy. i did have to remove the door panel though. but that wasn't hard.
Bubbagump_357
I have a 2004 chevy 1500 with power mirrors and they are non heated. I heard you can put the tow mirrors that come with the heated function on them and just leave the heat plug undone. Is this true or is there a place I can get the square bulky looking tow mirrors with just power and manual folding
Blue2002Tahoe
I know this is an old thread, but can you post a photo of the front of your yukon? I want to see what the roof marker lights look like. Thanks
BlacktopBandit76
